Question about Hotpoint BWM12 Front Load Washer
Hi the drum won't go round but the control dial is spinning. The model is the hotpoint bwm12. Any ideas??
Belt might have slipped off.
Posted on Oct 09, 2010
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
Dial keeps clicking around like a clock and drum still full of water
the dial clicks to indicate an error code as it turns the light will fash a code out -likly code will be 5 flashes which indicates pump blockage-check filter
Nov 12, 2009 | Hotpoint BWM12 Front Load Washer
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Feb 19, 2009 | Washing Machines
Hi,my hotpoint wf541 washing machine has become noisy on its spin cycle,any ideas as to what is wrong with it,or can you recomend a repairer for me in Lincoln,uk?
Try spinning the drum by hand ,if it feels or sounds noisy, then the main bearings have gone, if no obvious niose, then it could be m/c not level, overloading,-loose balance weight)(s)-suspension spring broken or unhooked--there are other causes, but these are the usual things to look for.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint BWM12 Front Load Washer
MY HOTPOINT BWM12 1200 SPIN WON'T DRAIN,
You need to check and clean filter first.
You will find the filter is normally located behind a removable plastic cover at the front right side of the m/c.
Make sure the drain hose is not kinked or restricted..
Make sure you have not selected rinse hold..
Obviosly make sure pump is actually working.
Plz rate this solution .Thanks.
Dec 24, 2008 | Hotpoint BWM12 Front Load Washer
Dial keeps turning on machine
machine wont operate when dial is at rinse
Jul 17, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint BWM 129 washer
ARE THE PADDELS BREAKING OR MELTING.
Jul 16, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA58 Washer won't do proper final spin
I ve come across this problem many a time... my job is recondtioning these models of machines for the last 3 years..
This problem has three solutions..
the first one is the control board,, very unlikey but has been known,
secondly the wiring loom unlikey but has happend.
Thridly the motor itself ....This is the most common remedy to this problem.
Dec 23, 2007 | Hotpoint WMA58 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
123 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
