Question about Sony PlayStation 2 Slimline Console
Slimline PS2 The laser is working fine now but now the spindle only spins slightly help?
  • Anonymous Aug 17, 2008
    everything works spindle just dosent spin
    Scholar:
  • 65 Answers
Check for hair or any other particles in the spin shaft.
-Rel
Posted on May 30, 2008
Hello my ps2 dont spin it not the lens can u tell me what worng with it or how to fix it the part that you put the disk on dont spin
The spindle (spin) motors don't usually go out. The most common reason for the game to not spin is the laser. If the laser doesn't see a disc then it will not try to spin it. You can pick up a new laser off of ebay for less than $10
Dec 01, 2009 | Sony PlayStation 2 Slimline Console
My ps2 slimline doesnt work the spindle
If the laser doesn't see a disc, then it will not try to spin. First try cleaning the laser eye with a q-tip and some rubbing alcohol. If this doesn't work, then the laser has probably gone out. A new laser can be purchased on ebay for less than $10.00
Nov 13, 2009 | Sony PlayStation 2 Slimline Console
Ps2 slim spindle dont spin
If your spindle has stopped spinning, it will most likely be 1 of 2 problems. Either your spindle motor has burnt up, or even though it is very unlike, a lead wire that supplies the power to the spindle has became disconnected. Now, if the case it the burnt up spindle motor, there are hundreds of motors for every kind of PS on, of course, E-Bay. If the problem is for some reason, a soldered wire has broken from the motor. It is very simple to re-attach the lead with a quick touch from a soldering iron. I hope this has helped.
Jan 02, 2009 | Sony PlayStation 2 Slimline Console
PS2 won't read disk sometimes
I've helped someone else with a similar problem here: http://www.fixya.com/support/t1300166-playstation_2_console_keeps_freezing
It's not enough to use a disk to clean the laser lens. You have to take the PS2 apart and clean the lens manually. Nicotine, Incense, diffusers, and other smokes and just time itself clouds the lens. Not only that but the part that the disk sits and spins on needs to be cleaned over time as well to assure the disk is in proper alignment and Is not just kinda spinning on the spindle.
In that link i posted above you be led to directions on how to take apart your PS2 and what parts to clean. The instructions I have posted in that tutorial is for the (FAT) PS2 model not SLIMLINE. If you have a slimline model you don't have to take apart anything just open your cover and clean the parts in the video.
Hope that helps,
9x|
Nov 30, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 Not spinning disc
ok you hav ridep a motor ribben replase and it should work
Nov 27, 2008 | Sony PlayStation 2 Slimline Console
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Won't work. disk won't turn
sounds like a faulty spindle. this is the part that spins your cd for the laser to read. if your using a fat ps2 its prolly the spindle. if your using a slim ps2 it could be the laser causing the problem not the spindle. the slim ps2 laser make the spindle work. if the laser isnt working right the cd might not spin or it might not spin fast enough or flat enough.
look
Mar 06, 2008 | Microsoft Xbox 360 Console
Please.. help me... my ps2 slimine is comepletely ruined..
Since you "smashed" which made things much worse (been there, done that). It was probrably fixable but now that it scratches I can only assume that the lens (laser) is scratched and damaged "beyond repair". The only suggestion I have, if you really want to fix it is to replace the lens and probrably the disc tray too. Fot the trouble it's worth too fix and the fact that there is no guarantee that it will even work after you fix it, your best bet is too buy a new one or at least a refurbished one.
Jan 06, 2008 | Sony PlayStation 2 Slimline Console
PS2 Disc does not spin
just because you see read doesn't mean the laser is good.
the laser has to read the toc (table of contents) for it to read the toc it must be at the beginning, it must be at the right depth from lens to cd and the spindle must spin. now if you have to spin the spindle that means it most like is not reaching the beginning of the cd or the spindle motor is bad.
Jan 02, 2008 | Sony PlayStation 2 Slimline Console
Faulty PS2 v12
Hello shaundiane, first of all try by replacing the optical block unit. If the problem persists, continue with replacing the RS2004FS driver IC. Best regards, Arpi
Jan 24, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
