Question about Motorola Mobility RAZR V3i Cellular Phone
My cell phone is not charged when connected to the charger
  • 998 Answers
Try to check the charger terminal if its corroded
Posted on Oct 09, 2010
Not charging
Hello My Dear Friend::::::::::"
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Sony Ericsson Z550i Cellular Phone
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
Cell won't charge even with a new battery
Try to use or buy universal charger. Get your battery and charge it to universal charger. so that you can use your phone. This is the easy way so you can use your phone.
Jan 25, 2011 | Cell Phones
Nokia 3110c Charger not supported
First Option:
Second Option:
Dec 29, 2010 | Nokia 3110 Cellular Phone
Phone not charging unless i hold it in my hand and squeeze the charger. Same thing happens with a new charger
Try to reduce the length of wire of your cell's charger.Cut the wire of your charger and reduce its length.Reconnect both wires the same way they were connected before and please make sure wires wont touch each other.Set your phone at charge and see if its charging,if not then connect the wires again but differently.
If you have the same problem with other chargers too then the problem is with your charging port.You'll have to take your cell to cell phone repairer.
Thank you!
Feb 17, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Motorola Razr phone charger gets message, ''unauthorized charger.
The problem was in the point of connection between the charger cord jack and the cell phone charger receptacle.  By moving the jack within the connection I was able to resume charging.  The connection may have become faulty as a result of heavy usage.
Feb 15, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Warning bad connection charger
charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
Nov 07, 2008 | Dual Electronics N99i Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
