Question about Samsung LN-T4671F 46 in. LCD Television
The entire right half of my Samsung 46" lcd model #LN4671FX has a shadowy flicker. How can I fix?
If I were you I would first try switching which HDMI port you are using, and if you have a different cable, try that also. Also, it could be that the connection itself got loose. These are things you can do before sending it to a tech and you have to box up your tv and send it. If you just purchased it, take it back to the store and get a new one. Also, check to see the panel type on the box. There is a real cheap panel that is being shipped on one MFG's TV's and they used to be S-IPS panels, and stated so on the description. Now they don't state and some people are getting a "V-Panel" instead which is way less quality. S-IPS = Super enhanced panel, very high quality. Please check this if all else fails. If you do have a V panel please post so others can complain about Samsung using cheap products to save a few cents. For people in China this may be okay but not for people in the US. Also, if you are viewing an over the air channel on a cable or sattilite box, see if you can view it via the antenna and see if you get the same problem. It might be comming from your cable or sattilte box, or bad wire, not plugged in all the way, or bad port. Good Luck and post if you try anything.
Posted on Mar 03, 2011
  • 998 Answers
You should bring it to the samsung service center it has a broken module they can replace it
Posted on Oct 09, 2010
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
Mar 02, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
My 42 in Samsung (LN46A530) TV is flickering when I turned it on and it stays for a very long time.
A lot of the Samsung's have a common issue, there is a jumper in the power supply that needs to be removed, Contact Samsung with the model number and they can tell you if your set is one, they were fixing this issue for free.
Dec 14, 2012 | Samsung LN46A530 46 in. LCD HDTV
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
Samsung LCD 46 inch half of the screen is darker than the other half.
Hi, while fixing another persons lcd tv i used lower rated power supply to try to fire up the tv ( picture-no sound) the bulbs ( actually cold cathode fluorescent ) lit up but only halfway. So sounds like the power supply for your backlight has gotten weak. You may try a workaround I've used on personal equipment, try turning down brightness on tv-this may,if your lucky, even out the brightness. hope this helped. Prodzilla
Mar 30, 2011 | Samsung LN46A650 46 in. LCD HDTV
Samsung LCD model LNT4665F went completely blank with no picture. I replaced t-con board today and now the t.v. is bright and greyish, has two vertical gray lines and screen images are colorless and...
It sounds like you did not properly reinsert the ribbon cables, also verify that you do have 12vdc feeding the T-CON board, you may have to clean the contacts on the connectors also.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
Half of my lcd tv gets dark no picture
Find your warranty papers....may be a defective screen.
Apr 21, 2010 | Samsung LA46A550 46 in. HD-Ready LCD TV
Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Dec 15, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung LN-T4671F 46 in. LCD Television Logo
156 people viewed this question
Jerry Greenberg
Jerry Greenberg
