Question about Equinox (210120)
Dosen't always start
There is nothing wrong with starter it has been checked somtime it starts and sometimes it dosen't
  • HDchik80 Oct 07, 2008
    I have the same problem with mine. I have to try a few times to get it started. It acts like it wants to start, but keeps turning over and doesn't. Usually works on the second try though.
  • tbutler88 Jan 28, 2009
    I have a problem with my 2005 Chevy Equinox. For some reason, every 8 to 10 months, the battery begins to weaken to the point where it will not start the car. Everytime this happens, the CD player seems to have trouble shutting off. It buzzes and clicks and makes the same sound it makes when I insert a CD but it does it constantly for about 2 minutes. I'm wondering if the CD player is not properly shutting noff and therefore slowly draining the battery at night.
    Has anyone else out there had this problem?
    E-mail me a tbutler88@hotmail.com
    thanks TED
This problem happened to mine as well... I took it to a local garage and they did a throttle body service and fixed the problem, I asked what a throttle body service was and they said it was just spraying some cleaner into the throttle body while working the throttle was all it was.
Posted on Aug 10, 2012
Starter problems, Suggestions???
Starters tend to fail intermittently. Yes, if it started after a "whack", I woul suggest replacing your starter. Make sure all connections are tight and of course clean terminals and cables.
Sep 03, 2016 | Cars & Trucks
I have replaced battery and alternator ok but the problem is now when I shut the car off it won't start is it my starter? I let it sit and will sometimes start up easily and then it won't somtimes
lots of variables does it turn over and not start --does it click and not turn over or does it do nothing -----if nothing check connections and relays(over heating or going bad)---turn over no start --check fuel pump and relays /wiring------clicks --check starter possible solenoid going bad connection loose or damaged relay problem ---ignition switch problem
Aug 21, 2015 | Cars & Trucks
DIALS ON DASH GO CRAZY, ALARM GOES OFF AND CAR WON'T START. HIT PANIC BUTTON THEN TRY AGAIN. SOMETIMES IT STARTS LIKE NOTHINGS WRONG AND OTHER TIMES YOU JUST KEEP TRYING. COULD IT BE A BAD GROUND?
If this is a after market weekend mechanic boy racer alarm thingy then get a pair of side cutters and remove it .these things are made using inferior made in china micro chips and are ALWAYS going wrong
Dec 28, 2011 | 2002 Ford Thunderbird
Will start sometimes and wont start sometimes. batt is good. do you think it is the starter? it doesnt do it all the time
If the starter rotates [ turn-over ] the engine, then it isn't the starter. If it dosen't turn-over all the time, then it could be the problem. Other items that will cause issues are the nutrual saftey switch,or the igntion switch.
The starter can be tested in the car, many autopart stores will do this for free.
May 05, 2011 | 1997 Buick Park Avenue
I have a 95 monte z34. it is hard to start. the starter heats up and the coil pack sometimes smoke. but once it started it runs great but once you turn it off you cant start it back up for hours. someone...
hi, this sounds like INTERNAL SHORT IN THE STARTER MOTOR( the brushes wire contacting the comutator) meaning the BRUSHES are WORN. smell of burning from starter motor. (somtimes the starter motor stays engaged to the flywheel and the starter motor go's supersonic and distroyes itself). but get other advice first. in case i am wrong. DO NOT RELY ON MY ADVICE. gerry
Sep 11, 2010 | 1995 Chevrolet Monte Carlo
I have a 2001 Ford Expedition. Sometime the car
THATS A TYPICAL FORD DESIGN THAT YOUR STARTER IS GETTING READY TO GO OUT. EVERY FORD THAT THE STARTER WENT OUT ALL OF THEM DID THE SAME THING.THEY ALWAYS WORN YOU.
Apr 16, 2010 | 2001 Ford Expedition
Car wont start
sounds like the starter to m,e
Jun 02, 2009 | 1999 Ford Taurus
Not always starting
having start problems. It will start when battery is fully charged. If not have to go under the car to spark a start. What do i need to get it going right again. John
Apr 30, 2009 | 1991 Buick Century
Intermittent starting
check the igination switch.
do you get power to the starter???
you need to check first.
Oct 10, 2008 | 2000 Daewoo Leganza
Equinox (210120) Logo
74 people viewed this question
Top Equinox Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you an Equinox Computer and Internet Expert? Answer questions, earn points and help others
