Question about LG Dishwashers
LD-2120WH have code error on screen IE and sometimes a F all messages are flickering what does it mean? Please help asap thanks
2 Suggested Answers
SOURCE: I have an LG dishwasher,
I've just solved the same problem on my 2120. It started when the pump motor bearing failed and continued after I'd replaced the bearing. According to my handbook the E1 fault is theoretically a water leak but practically it is that the pump is not delivering enough water. In this case the failed bearing had allowed the shaft to wobble about and damage either the rotor or the inside of the pump (it's sealed so you can't strip it). Solution was to replace the pump.
Paul H
Posted on Nov 28, 2010
Dishwasher LG ld-2120wh has a F on the Auto switch, what does this mean
it means that is testing the washing cycle , It uses only what it needs to use of your powerball dishwashing detergent by testing the water . The F is displayed while it tests the water in the dishwasher to determine how much detergent it needs.
Apr 15, 2014 | Dishwashers
Dishwasher LG ld-2120wh have F on the Auto switch, what does this mean
F is displayed when the dish washer is testing the water to see if more dishwashing powder should be used when in Auto mode. To do with saving the environment to use the least amount of detergent
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
My washer has an error message LD on the screen and all the lights are blinking. The load seems to be half way through (towels are still soapy). I can't get it to unlock the door and pressing power or...
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
What does error code LD mean?
"Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back thank you again and have a nice day
rickead1
Aug 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727) Timestamp: Tue, 1 Dec 2009 01:53:04 UTC Message: 'fbjs_fbml_string' is undefined Line:...
Hello
Thank you for using FixYa for your problem
What version of IE8 are you running, (image is showing beta) but do a IE update and maybe a reset for IE, (tools, Internet Options, last tab and you see the reset button)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Microsoft Internet Explorer 8
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
112 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
