Question about Plantronics Voyager PRO Bluetooth Headset
I have a plantonics voyager pro. It won't pair with Nokia 7230. How could I solve? this problem? Serra
    Master:
  • 473 Answers
Check First If it Compable with Your Nokia 7230... From the net type Bluetooth programmation with Nokia 7230... Then Read Instruction., Good Luck
Posted on Oct 09, 2010
Cant get my voyager 510to connect to my nokia c2-01 mobile phone can you help??
Because this is a discontinued model going with a very new phone. I hope it works for you. Otherwise you may have to purchase a new headset. However when they discontinued that they did not make a replacement. You may want to look at the Voyager Pro HD.
Plantronics Voyager 510 Pairing Instructions
Plantronics Voyager Pro HD
Good luck from Headsets Direct!
Sep 29, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My voyager pro doesnt work with my skype on iphone.
It may have to do with the settings that are listed on Skype. Because you are using the headset with your phone, it should work with the Skype application, so please check your settings. If it continues to not function correctly, try re-pair or subscribing again.
Below are two links which may help you solve your issues:
Plantronics Voyager Pro User's Guide
Plantronics Voyager Pro Pairing Instructions
Jul 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
I am geting really bad staic in my plantronics voyager pro. I have the HTC EVO. Is there any way to get rid of the static?
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a samsung rogue and I all I hear is mostly static with the Plantronics Voyager PRO
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Dec 25, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cant set to my phone
Dec 13, 2010 | Plantronics Voyager PRO Bluetooth Headset
I have a plantonics voyager pro. It won't pair with Nokia N86. How could I solve? this problem? Mashary Thank you
There could be interference from other Bluetooth devices on your phone. I would delete or disable them from your phone. You can also try taking the battery out of the phone for about 30 seconds and then try relinking the two. User guide listed below.
Dec 05, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cutting in and out. best described as sounds like i am talking into a fan.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions:
http://www.headsetsdirect.com/plantronics-voyager-pro-bluetooth-pairing-instructions
Also if you have a different phone available just to test, see if it does the same thing.
Sep 15, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager PRO  Bluetooth Headset Logo
149 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
