Question about Sony Ericsson W760i Cellular Phone
Does not light up when i slide open - Sony Ericsson W760i Cellular Phone
  • 358 Answers
Hi, The flex of the phone.The flex is connected to the screen and it makes the phone light display,if the flex gets damaged it will make the phone light display be affected.
i hope ,i will help you ,thanks for trusting fixya...
Posted on Oct 09, 2010
The bulb lights up but it does not drop the photo to view
Hi Faye,
There is a "dark shutter" that blocks the light that probably is not opening.
It can be adjusted, but requires some tools and a bit of patience.
The process to adjust the DARK SHUTTER is:-
[1] Remove for the LOWER HOUSING.
[2] Insert a thin SLIDE into the GATE MECHANISM; the DARK SHUTTER should open.
Hope this helps you and you have the slide projector working again soon.
Regards,
Michael
Mar 10, 2014 | Kodak 4200 Slide Projector
My projector will not show the slide.Everything else seems to be working.
I'm assuming the lamp is lit, the light is just not coming through the optics. You didn't specify the model, but most later manufactured Kodak projectors have a "dark shutter". This feature keeps the blinding light off the screen when you arrive at a spot in your slide tray without a slide in it. It senses a slide dropping into the slide gate, and pops the shutter open. Otherwise the shutter stays closed.
One of 2 things has happened:
1. The spring that "pops" the shutter open has fallen off.
2. The "dark shutter" latch needs adjusting.
You can find the Kodak Service Manuals that will give you instructions for adjustment and or replacing the spring at:
http://resources.kodak.com/support/pdf/en/manuals/slideProj/carousel_ServiceManual.pdf
Good Luck!!
Jim
Aug 13, 2012 | Office Equipment & Supplies
How do i open the battery door on my D3000
Try again. Slide the tab and pull on the door lightly. Or after sliding it, keep the slider in that position and turn the camera upright so that the battery presses against the door.
May 16, 2012 | Nikon D3000 Digital Camera
The van was hit on the back passenger side resulting in a dent . The open door light along with the interior lights flashed when I hit a bump. I hear something that sounds like a fan continuosly blowing....
I think this may be the "closer" motor continuously trying to gain a positive latch--and unable to do so. This could be from a damaged latch switch.
The sliding door has three motors, a slide motor, a release (or unlatch) motor, and a closer (or latching) motor. The open door light and interior lights coming on seem to indicate that the "closed and latched" switch is sometimes open-- allowing the closer motor to continue to operate.
Another possibility is that the dent has changed the geometry of the door mechanism especially the draw of the pull cable. The slide motor has a sensor that pulses when it runs. The door management controller counts the number of pulses of the slide motor sensor to determine when the door is fully closed and then stops the slide motor. At that point, the closer motor operates to latch the door. If the cable geometry has changed, the door controller may be shutting off the slide motor prematurely and the closer motor cannot complete the latch.
Mar 28, 2011 | 2000 Honda Odyssey
The nokia n95 won't unlock when slide is open and no lights
There is a possibility there is a problem with the ribbon of the slide let a technician check the ribbon of your phone.
Jun 09, 2009 | Nokia N95 Cellular Phone
Nokia n96 back light
slide your phone open and the back light does not turn on. slide it closed and then wait until the front keypad light turns off and then slide open straight away. you will find that the back light then comes on. bit of a puzzler and a pain but has seemed to work so far.
Jan 08, 2009 | Nokia 5310 Cellular Phone
Lights flash when opening power doors
when you open the power sliding doors the turn signal lights are supposed to flash. are there other lights that flash?
Dec 29, 2008 | 2005 Dodge Caravan
Slides skipping
open it:1-visual inspection of broken cams-gears- levers weak tension spring-use air can of compresed air to clean it (radio shack)
use light grease and apply over mechnical parts.contact cleansr must be applied over switches.
Feb 16, 2008 | Office Equipment & Supplies
No lights in the touchpad when slide up
its probably the sensors inside your phone. most manufacturer uses magnet or sensing... if you can open your phone check if its still in place... if not visit your service center...
Oct 24, 2007 | LG KG800 Cellular Phone
I can't get the light to come on.
Sounds like your black screen shutter is not opening allowing light to pass through. Try it with the carousel and slides installed. Run a few passes.
Mar 05, 2007 | Vivitar V5000AF Slide Projector
Sony Ericsson W760i Cellular Phone Logo
146 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
