Question about Dryers
Do i take back or front off the machine to fit drive belt?
    Sergeant:
  • 286 Answers
You take the top panel off to see how accesable the belt drive is , mostly the are 3 sided(one piece) with a rear heater element/vent panel (seperate), make and model details would be good !
Posted on Oct 09, 2010
How can I hook up the snowblower attachment?
if its a garden tractor then you will first need to remove the mowing deck , this is easy if you have something to run front wheels up on to allow you room to pull deck out the side ,set deck height all the way down, save the drive belt . save the deck pins . locate the front chassis mounting arms and drive up to blower allow rear mounting arms to go between the two front wheels till the back of blower meets the front of chassis mounting arms (tight fit) install pins at all four points of contact , install belt to blower and front pto of machine (install any guards for belt) then raise blower from ground with deck height adjustment lever (it might feel heavier) test it to prove good contact your done
if its a three point (this is the reason I own one know) you back up to blower lower the mounting arms , engage the quick pins , install the drive shaft between the blower and machine with a quick spring snap , connect top link to tractor get back in seat and start machine raise three point an go !!
Jan 19, 2016 | Garden
I have a Creda 37374 Tumble Dryer and the belt has snapped. ive managed to get to the insides of the machine but how do i replace the belt as it looks as if it came off two pulleys next to the motor and...
remove the timer knob and you`ll see a small screw. remove that and the from control panel should slide upwards. once thats off you will see two metal rods/arms which fit onto the rear and the front of machine. remove the 2 screws holding the 2 rods/arms. the front of the machine can now be moved forward enough to get the belt over the drum. when the belt is over the drum, place belt onto the motor drive shaft (ribbed part of belt to ribbed pulley) then put belt between the sprung rollers and onto both rollers. make sure drum is then re aligned onto the bearing sliders on the front panel of machine. fasten back up. job done.
Jan 20, 2010 | Dryers
How can I change the belt?
you need to open the back up and look first study then remove it
Jun 10, 2009 | Electrolux EW1000i Front Load Washer
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Hotpoint aquarius 1300
it takes a fitting stap to fit but can be put back on by hand little tricky but can be done no probs
Mar 01, 2008 | Hotpoint Aquarius WD640 Front Load...
How do I fit a new belt on my Indesit Wil 113 washing machine?
I think its a 'front Loader'? Take the back panel off, to expose the main drive belt & pulley. When fitting the new belt it needs stretching by first putting it around the motor drive shaft & easing on to the main pulley whilst gradually rotatng the pulley. You need to finish up with the belt in the centre of both of the pulleys if possible
Oct 31, 2007 | Indesit W 123 Front Load Washer
Dryers Logo
29 people viewed this question
Top Dryers Experts
