I can´t get into menu on Lexmark X654de, because it promts me with a MarkNet password, i don´t know this password. How can i restore factory settings on this printer, please help me.
WhIzAtIt
  • 136 Answers
SOURCE: password problem
Usually all manufacturers use default passwords consisting of all 0's or 12345... etc etc or all 9's try it out!
Posted on Sep 15, 2007
AnOldMan
  • 6 Answers
SOURCE: need to reset to factory setting
Press reset button on back of unit AFTER system has fully booted (time will be displayed) and your system will be back to default values - password = applianceadmin.
You can also re-image the drive to factory defaults.
AnOldMan
Posted on May 16, 2008
SOURCE: Reset Factory Defaults
I fixed the problem with no help from your service....as a matter of fact, I mailed the guy back that "helped" me online and heard nothing from him either.
Good thing Im resourceful.......$15 WASTED!
Posted on Oct 15, 2008
SOURCE: How to Restore Factory Settings N99i
Shortcuts for phone settings
Change languge: *#0044# + dial for English
Check Version: *#8375#
Firmware verion: *#8882#
Test*#87#
Debug*#8899# (?)
IMEI number:*#06#
Restore factory setting:*#66*#
Factory settings:*#3646633#
auto test:*#87#
Password for restore factory settings: 1122
Posted on Jan 11, 2009
  • 26 Answers
SOURCE: Password Problem Phaser 6120
Unfortunetly, you will have to reset the printer. Using the control panel go to the default setting and scroll to reset to factory settings. Then select yes and that should take care of it. If not, then in the rear of the printer under the cover, upper left side you will find the memory button battery. Remove the battery, unplug the unit, and turn it on for about a minute. Turn it off and put it back together and you should be ok. Good luck.
Posted on Apr 27, 2009
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
Lvps cooling fan failure on lexmark x654
LVPS cooling fan is obstructed or has failed.
1. Check for cooling fan obstructions.
2. Check the connections on the main cooling fan.
3. Replace the print cartridge cooling fan.
Nov 12, 2012 | Lexmark "x654de multifunction monochrome...
927.21 lexmark error
A 927.17 is a LVPS cooling fan failure: LVPS cooling fan is obstructed or has failed.
3. Replace the LVPS cooling fan.
Lexmark T642, I forgot my Admin password
- Select "Reinit NVRAM" Method 2 (with Config Menu): - Press c:%5cdocume%7e1%5ccamores%5clocals%7e1%5ctemp%5cmsohtmlclip1%5c01%5cclip_image006.jpgwxctwy11ul1zqaaaabjru5erkjggg== and c:%5cdocume%7e1%5ccamores%5clocals%7e1%5ctemp%5cmsohtmlclip1%5c01%5cclip_image004.jpg pz+7jx7h3zm6uuwsrlxaaaaaelftksuqmcc while POR - Select "Factory Default" -> - Select "Restore Network" - - Press wxctwy11ul1zqaaaabjru5erkjggg==c:%5cdocume%7e1%5ccamores%5clocals%7e1%5ctemp%5cmsohtmlclip1%5c01%5cclip_image006.jpg If you have questions about your Lexmark printer, please feel free to contact us at LxkListens@Lexmark.com
Aug 24, 2012 | Lexmark T642 Laser Printer
Forgot admin password
Hi, What you need to do is to reset the NVRAM. That will also delete your network information and passwords you set for the printer. Please see steps below: Method 1 (from Standard Menu): - Network/Ports -> press LEFT ARROW button and RIGHT ARROW button simultaneously -> Select NVRAM -> Select "Reinit NVRAM" Method 2 (with Config Menu): - Press CHECK button and RIGHT ARROW button while POR -> Select "Factory Default" -> Select "Restore Network" -> Press CHECK button If you have questions about your Lexmark printer, please feel free to contact us at LxkListens@Lexmark.com
How to clean a X654de LexMark Printer cartridge to get more copies out of it?
1.Take out the ink cartridges
2. get a soft cloth or papertowel
3. you are going to need a bit of isopropyl alcohol
4. take a tiny bit of rubbing alcohol and dab the place where the ink comes out with it lightley
5.Be very carefull! leave it out to dry for at least fifteen minutes
6. then put the ink cartidge back in to your component
7. make sure that the cartridge is in place and pushed in the right way so that it can be used properly
THIS MAY BE A BIT MESSY SO I WILL ADVISE YOU TO WHERE GLOVES!!!
HOPE THIS HELPS!
Jul 15, 2010 | Lexmark X654de MFP All-In-One Laser...
I cant talk to m print server
make sure the lan cable is properly connected and the ip address is correct and you are able to ping the ip of print server.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 23, 2010 | Lexmark MarkNet X2011E Print Server
Network card, Token Ring fitted, what card do I need for ethernet?
You will need to use Lexmark's MarkNet N7002e print server.
Check this link:
http://www.lexmark.com/lexmark/product/home/500/0,6970,204816596_653399458_253501940_en,00.html?tabId=7
Oct 16, 2009 | Lexmark Optra S 1255 Laser Printer
LexMArk Marknet 700Oe: Booting problem
hmmm...ok..you'll need to reinstall the server software, where those reside..
Jun 15, 2008 | Lexmark MarkNet N7000e (1 USB port) 10/100...
Old IP address
You can reset the MarkNet X2000 to factory defaults - which includes resetting the IP address to 0.0.0.0 like this:
1. Press and hold the Test button until all four lights stay lit simultaneously, then release the Test button.
2. When #3 and #4 lights light simultaneously, press and release #1 (the Menu button).
3. When #3 lights press and release #1 (the Menu button).
4. At this point the X2000 print server has been restored to the factory default settings and should have an IP address of 0.0.0.0.
-John
Feb 06, 2008 | Lexmark Refurbished MARKNET X2000 SERIES...
875 people viewed this question
jasbo
jasbo
