Question about Sharp AR-5316 Advanced Digital Imager Copier
L 1 blinking
Error message is in the following manner first L FLASHING AND 1 FLASHING ALTERNATIVELY .PLEASE PROVIDE THE SOLUTION .
  • 146 Answers
L1-00 is a mirror base feed trouble. Make sure the scanner mirrors move freely. Check for a scanner lock usually underneath the scanner frame to make sure the mirrors aren't "locked". otherwise check the cables and belts in the optics section but do NOT didassemble them without experience doing so. Lubricate scanner rails. Usually caused by accidental scanner lock engagement.
Posted on Jun 04, 2008
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Whirlpool dishwasher flashing lights
7 blinks followed by a pause and repetitive 7 blinks problelm fixed by alternatively toggling between "heated dry" and "normal buttons within 6 seconds
Aug 18, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
No power, fast blinking flashing green light where I plug power cord in.
Good day
Kindly provide the following for us to provide a direct and final solution to your problem
1. Does the blinking light changes from yellow to green or vice versa? 2. Is there a blinking red light? 3. How many blinks do you think it blinks?
Should you have any questions regarding the questions above, feel free to approach and ask us.
Good day and God Speed.
Jun 14, 2010 | Computers & Internet
Troubleshoot issue
please provide more details of your problem (ex. error code, error messages, operating system)
alternatively try to uninstalled the messenger and then reinstall it.
don't worry about your contacts or emails, everything will be there after your reinstall.
Apr 19, 2010 | Yahoo Messenger
Message Light
press #409 to cancel message receive
press #64 follow by et\xtn on display to cancel sent message
mayb st 21 been assigned, but no body know.to check, call from all extn to displayed phone.check 1 by 1.
if light keep blinking for mic, try to change other key phone
May 27, 2009 | Toshiba DKT-2010 Corded Phone
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
Toshiba cz32v51power light flashes, with no picture
That means that an internal error had been detected, and now the TV is on protection mode.
To start unplug the power cord for ten minutes, and see if the TV restart.
If it does not try leaving the set unplugged for longer, let say two hours.
If still no luck call the number listed on the user manual, as the TV has an internal fault, and must be repaired by a technician.
Jan 14, 2009 | Toshiba CZ32V51 32" TV
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
I had the error message L-4 .can you halp to fix this problem?
L6 is a laser polygon motor fault, you need to replace the polygon motor in the laser unit, but try the reset code first sim 14
May 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
