Hi, I have a Sony LCD Projection Tv ( Bravia Kf-42E200A ) I have just recently changed my lamp and it worked great for 15min, then it switched off and now when I switch it on the green lights flashes for about a minute and then the red lights blinks 5 times every 5 seconds, and the screen stays blank Can any one help me?
https://www.sony.com > support > kf-50we620 > faqs
LCD Projection TV HD-Monitor Grand WEGA® / Included components may vary by country or region of purchase: RM-Y913 · Questions & Answers · Is this page helpful?
Log on to www.sony.co.uk or they have a phone number Sony Information Centre 08705 111 999 Mon-Fri,9am-5pm.Will try and find manuel,might have thrown out by mistake.
This is a classic case of a faulty lamp(even though it is new). Possible that it is a ballast(lamp power sply) problem but it is more likely that the lamp doesnt quite meet the required specifications. Your lamp may be a Non-OEM or a refurb. You should try to get it exchanged with the vendor you bought it from.
justlamps.com is a great source for bulbs.
good luck
The lenses in the TV are more than likely misaligned due to heat from lamp. The heat can cause the lenses to move and the red shaded horizontal line appears over time because the lenses fall out of alignment.
You just need to have the lenses realigned and the red shading will go away.
New bulb is just fine. 3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position. Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly. Turn On TV and get vivid picture of Sony. Thanks.
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
