Hi
Thanks for using FixYa. Error code F/H means no water was detected entering
machine or pressure switch trip not detected. If after 30 seconds the
control does not detect water entering machine the valves will be turned off
and the error code will be displayed. It can also happen if the control has
turned the water valves on and after 8 minutes the flow meter has detected 10.5
gallons of water passing through it but has not detected the pressure switch
trip, the valves will be turned off and the error code will flash. You'll need
to press PAUSE/CANCEL button twice to clear the display. Please accept
the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
As I said FH means no water was detected entering machine or pressure switch trip not detected. The first thing will be to check the water inlet valve and try to clean it for clogs, if that is fine then it is the pressure switch which should be replaced. Let me know if you want to do this yourself.
Hi thanks for the advice. are you fairly sure this is the problem? the conditioner dispenser was not activated either. the machine has just done a half cycle on the daily load setting before showing symbles FH. If the problem is the pressure switch trip then how easy is this to fix? how much is the switch and would I need an expert to fit it or would I be able to under your guidence?
Many thanks, Richard.
