Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Creative zen 60gb
1. Clean Up
2. Format All
3. Reload OS
4. Reboot
i am getting this screen
tried them all
nothing happens
when i tried to 2. format all, it gave me a message saying problem with hard drive
and then went back to menu
the whole story is that i took it skiing
and it got a little bit of snow on it and went off
and that was it
the case was on it
The hard drive here is shot. You will need to buy a replacement hard drive.
Posted on Jun 03, 2008
My CREATIVE ZEN Micro doesn't play any media after i accidentally dropped it. Is there hope?
1. Ensure that the player is turned off
2. Remove the battery.
3. Move and hold the Power button to the Power On position and re-insert
the battery to the Zen Micro. Hold the Power button until the rescue
mode appears.
4. After 2-3 seconds the rescue menu will be displayed.
At this point the battery can safely be replaced and maintenance options
performed.
5. Four options will be displayed on the LCD screen:
? Clean Up - (To rearrange your stored data)
? Format All - (To format and remove all data)
? Reload Firmware - (Reloads your player's operating system - Do not
choose this option unless you have downloaded a firmware update from the
Creative website)
? Reboot - (Restarts your Player)
6. Select the Clean Up and then the Reboot option.
Now, please try turning off the player.
Jun 07, 2010 | Creative Labs Zen Micro MP3 Player
Mad at my nomad
It appears that my Creative Nomad Jukebox is stuck in the Rescue mode. It displays the four options suchn as. 1.Clean up 2. Format all 3. REload OS 4. Reboot
It is not recognised on the computer either.
Steve
Dec 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen Touch in Recovery Mode
can you choose any of the options 1-4? try to clean up.
Jun 24, 2008 | Creative Labs Zen Touch MP3 Player
Recovery Screen, take 2.
If your Zen is not responding or in a "reboot loop" the following information from creative explains how to access the players recovery mode
Hope this helps, and good luck.
Zen V Plus and Zen V
1.
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Dec 27, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Nomad Zen Xtra 30 GB
Holy **** suggestion 4 worked. Top right side near the menu button - a little whack with the middle finger knuckle, and you can actually hear the hard drive spin up. I still like this player - 30GB for heaven's sake !!! and any iPod that comes into this house goes to my kids anyway. Might be time to make a backup of all the music though....
Nov 16, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative zen
· Download recovery tool off creative's website.
http://us.creative.com/support/downloads/
Sep 30, 2007 | Creative Labs Zen Touch MP3 Player
Zen Microphoto frozen..
Solution ID # 4794 from creative site ZEN Micro and ZEN MicroPhoto 1. Make sure that the battery is charged. 2. Detach the ZEN Micro or MicroPhoto from the PC, and ensure that it is turned off. 3. Remove the battery. 4. Move and hold the Power button to the Power On position and re-insert the battery to the ZEN Micro or MicroPhoto. Hold the Power button until the Recovery Mode appears. The following options will be displayed: -Clean Up : Scans the player and removes invalid links from its music library.Does not affect music files themselves. -Format (All):Caution! Erases all content!Save a copy of your player's content before formatting. -Reload OS/ Firmware : Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
Jul 29, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Problems with turning on
Sounds like it may be the index in your Music Library. Try going into Recovery Mode the routine way; remove battery(are they charged and good?), hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart/Reboot. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 28, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
63 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
