Question about Garden
Tractor work,s great untill it get,s hot. then it won,t pull hardly at all. works better in cold weather
    Novelist:
  • 144 Answers
First thing to check would be the covers around the engine. You don't list what brand of tractor or the motor but a common problem with all are the shields surrounding the top of the motor. These shields are not just to protect you from touching a hot surface, they are actually designed to help air flow around the cooling fins of the cylinder. It is very common for debris to build up in this area (from mice, or other critters, or just alot of grass clippings etc.) You need to take these covers off and clear out any debris around the cooling fins. That should solve your issue and prolong the life of your tractor. Hope this helps!
Posted on Oct 09, 2010
How would hot plugs go in my vt99 commodore last ye asd in cold weather it took ages to start of morning had 4000 worth of stuff done to it and never fixed it thru summer its great. So what would u advise...
You really need to read the plugs that are in the car at the moment. If the porcelain around the center electrode is black or chocolate brown around the tip you could go a little hotter. This will not do much to help with cold starting in winter. You would be much better of upgrading the coil or coils and running clean plugs.
Feb 05, 2015 | Cars & Trucks
Overheating gage when stop & go -2004 chevy tahoe
natural for engine temp to rise in Traffic - Until Themostat opens ) cooling fan sensor kicks on fan . But Antifreeze is not just a Cold weather item . Coolant is Absolutely Necessary for Hot Days . You must be full to recovery bottle setting of cold when checked prior to start up . Coolant for your make / model is Reddish - Pink colour and should have a reading of -25 thats negative 25 degrees the Lower the Better even - 50 .. Why ?? - 50 is 50 %% antifreeze / Coolant Concentrate MIX Gives Hot weather cooling Ability or very cold weather starting / winter HEAT .
Mar 14, 2014 | 2004 Chevrolet Tahoe
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
Problems starting in hot weather
remove gas cap in hot weather and see if it starts better. if it does its an emissions/purge issue
Mar 15, 2012 | 1989 Buick LeSabre
1999 Malibu hard start in hot weather, after it starts runs great lots of power. starts when cold in cooler weather.V6 3.1 engine. have gas at rail. changed spark plugs and wires, IAT and ECT sensors also...
this is most likely a fuel vapor issue.
fuel boils in the fuel rail causing a hard start after a 'hot soak'.
the fix is to replace the fuel pressure regulator and the pcm. good- day !!
Jun 30, 2011 | 1999 Chevrolet Malibu
What oil
Hot climate, warm weather, long distance riding 20w-50 is a great choice. Cold climate 10w-40 might work better. Use only a JASO MA certified motorcycle oil . Synthetics will help your bike run cooler and shift easier. Do not use any oil that says Energy Conserving on the label it will shorten the life of the wet clutch and transmission gears.
Oct 15, 2010 | 2006 Suzuki GSX-R 600
BMW 325, hard to start in hot weather.
before you try to start her again in hot weather, open your fuel filler cap, listen for any pressure release, close the cap, and try to start, if this works,then its just heat expansion in the fuel tank, replace the filler cap if this is the case
Aug 19, 2009 | BMW 325 Cars & Trucks
My 4.0 starts great when cold, but is very hard to start when hot. Any ideas?
Sounds like the electronic module needs to be replaced. Unplug the old one take out the mounting screws get a new one at the auto parts place plug it in replace the mounting screws and it should be ready to go it's not hard
Jun 27, 2009 | 1989 Jeep Comanche
8n tractor runs good at first then after awhile starts to sputte
Check fuel filter in the shut off bowl. Then check the needle and seat in the fuel sediment bowl on the bottom of the carb.Also check the float when you pull off the sediment bowl.
Apr 15, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
