Question about Microsoft Windows XP Professional
When I want to hear songs I could not get any sound from the speakers
  • subrahmanya sarmaemani Oct 10, 2010
    as advised I have checked the sound and music tabs and in sound tab 'no driver ' appeared.
    Sergeant:
  • 191 Answers
Check u connect ur speaker jack to correct LINE OUT port.(this is valid if u got working good sound card.so check it from this way
start-> run
type dxdiag
in sounds or music tab,find ur card showing.............
Posted on Oct 09, 2010
Hi grade laptop wont allow sound to come from the speakers
Make sure that the audio isn't muted.
On the little speaker in the lower right hand corner of the desktop double click on the speaker and make sure it's not muted.
Jul 07, 2012 | Computers & Internet
I have my laptop hooked up to the z506 surround sound speaker system. Since I don't have a good sound card or multiple ports to support 5.1 surround sound, the rear speakers do produce a bit of a...
Check that your mic settings in the Volume control is not maxed out. Turn the mic off and see if the fuzziness clears up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 17, 2011 | Logitech Z506
I want to hear music by using mp3-code.com
Are you not hearing any sounds when you are accessing mp3-code? perhaps you need to replace your headset or speaker. Or perhaps you need to upgrade your sound drivers.
Another possibility why your not hearing any sounds is that perhaps the songs that you chose to hear could be corrupted or has errors.
I suggest you refresh the page again and try to chose the same song again. Or upgrade some softwares in your applications
Nov 02, 2010 | Computers & Internet
I installed windows xp in my acer laptop computer, but in installed the sound driver too, the sound of computer is successfully installed,when I play a songs I can't hear any sound from my computer, i...
Go to the control panel / sound and check if the sound is set to mute ? if it is then untick the box and increase the volume. If you are playing songs from cd make sure its a working one. if the cd is fine and the sound is full you are not able to hear the sound then you will need to install the drivers for the card. use the drivers cd which came with the machine. After installing the drivers you should be able to hear songs if you still have issues then possibly somethings wrong with the soundcard / speakers.
Oct 18, 2010 | Computers & Internet
My mobile is nokia 3110classic.suddenly i got a sound problem.i cn't hear sounds outside.but am ble hear them through ear phones.i.e am unable hear songs as wells am not able to hear my ring tone...
The problem is with your "Ringer" (the bigger speaker). If you can hear the sound through your ear piece, then replacing the Ringer/Speaker will definitely fix your problem. I would suggest to get it done from a service center or from a mobile repairing shop.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Nokia 3110 Cellular Phone
Nokia 8900E crackle ring tone
check out the speaker
if its crackling even during songs playback then u will need to replace the speaker
May 24, 2010 | Cell Phones
Audio not working i can access only my head set .i can hear song only through head set only when i plug out my audio device speaker notworking.no problem for hardware.before i can hear song through only pc...
Double-click the "sound" icon (bottom-right, beside the Windows "clock") to open the "mixer" application.
Be sure that you have not "muted" your external speakers (not the internal PC speaker).
Sep 10, 2009 | Compaq Computers & Internet
Songs playing but its mute, incoming calls not ringing
you can check if you speaker is broken by using a set of headphones. if you don't hear sound when using your headphones there is something wrong with your software settings. if you do hear sounds using your headphones you need to replace your speaker. You can buy a replacement speaker on ebay and do this yourself, of search for someone to do if for you. If you still have warranty on your phone just return it to the shop that sold the phone.
Jun 15, 2009 | HTC Touch P3450 Smartphone
Downloaded songs appear in iTunes library but won't play on comp
I had exactly the same problem and followed the OP's solution, which worked, but I couldn't hear the track as it was being recorded.  So I tweaked the solution.  If you do the following, you don't have to keep changing System Preferences as you switch from record to listening:
Go to System Preferences, press the Sound icon, and click on "Sound Effects."  Then select the drop down menu and select "Play alerts and sound effects through selected sound output device" rather than the USB choice.  Then click on "Output" and select how you want to listen; I used speakers so I selected "Headphones" where the port is "Built-in audio."  Then click on "Input" and select the USB choice.  Now record a track and you can hear it being recorded through your speakers (or headphones).  When it's done recording and after the software transfers it to iTunes, you can play it again through your speakers without going to the preferences panel.
Dec 25, 2008 | ION Audio iTTUSB Turntable
Microsoft Windows XP Professional Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
