Question about Fedders D Chassis A6D24E7A Air Conditioner
FEDDERS D CHASSIS A6D24E7A
MY FEDDERS WINDOW UNIT BLOWS COLD FOR 5 MINS THEN THE COMP SHUTS OFF AND FAN BLOWS HOT AIR IF I TURN OFF THE AC UNIT THEN BACK ON THE AC COMP COMES BACK ON AND BLOWS COLD AGAIN FOR 5 MINS THEN SHUTS OFF AGAIN PLESAE TELL ME WHAT THE SOLUTION IS HELP
  • Jim Jul 13, 2008
    runs for approx 5 min, cools fine, then comp shuts off, when try to start buzzs, fan go. 20 min later comp will kick in again, will cool again for approx 5 min. Is cap start only for start or run too ??? Is the start assist that is two contacts on cap supposed to be hot? Does it break contact when comp draws too much current??? Jim_mc956
  • 981 Answers
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Posted on May 30, 2008
My fan is screeching but the compressor is blowing out cold air
sounds like you have bearings on there way out in the fan motor
May 21, 2012 | Fedders D Chassis A6D24E7A Air Conditioner
My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The outdoor coil is plugged with ****....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Fedders D Chassis A6D24E7A Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
Fedders Window unit
The capacitor's for running, too. The resistor across the capacitor is supposed to be warm but not hotter than boiling. Just disconnect the capacitor and check for a short if you suspect it; but it would be warm someplace.
The timer unit is usually reliable, but if it permits a thermal cutout after 5 min. and the cutout device is a little skittish, it could be either that cutout or a hot-side cutout (or thermostat) failure. Replace, don't bypass.
Jul 13, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Unit Does not blow cold air
compressor is not coming on or low on freon. Not something you can fix yourself.
Jun 10, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Air conditioner problem
You may have an extremely intolerant cold control, a weak gaurdette on the compressor, a compressor motor winding issue, or maybe an oversized unit for the area you are trying to cool.
May 30, 2008 | Heating & Cooling
Fedders D Chassis A6D24E7A Air Conditioner Logo
392 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
