Question about Linksys Wireless-G WRT54G Router
Help i have wireless connection with my linksys router but it wont display any webpage i want to searh
    Novelist:
  • 143 Answers
Check if you are getting a valid ip address (e.g. 192.168.1.x for linksys routers, not unless you changed the router's ip to something else) from your router. if so, try to disable any anti-virus software and firewall installed on your computer. if not, make sure that you are really connected to the wireless signal of the router. one common error message that'll let you know that you are not properly connected to the signal is "limited or no connectivity". if you're getting that message, try to disconnect and reconnect to your wireless signal and make sure that you are using the correct wireless security (network key) if you have enabled that on your router. it's also advisable to customized the wireless settings of your router to prevent interference from other wireless networks.
hope this'll help.
Posted on May 30, 2008
My internet modems wifi light wont turn on : WRT100 Linksys
to access page you need to connect it to a pc with an ethernet cable and in web browser address bar type 192.168.1.1 user and password is admin
Jul 31, 2012 | Linksys RangePlus WRT100 Wireless Router
Tip
Hi, I want to use the LINSYS Router as an alternate wireless acces point. I´ve...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Feb 20, 2009 | NetGear DG834G Router
The router has been reset by mistake and I don't know how to get my connection back for laptops. I currently have the dsl modem connected straight to the house computer. How do I get my router working...
Most DSL modems have their internal network set at 192.168.1.0/255.255.255.0
which is the same address space by default in your Linksys Router... more or less the routers IP is 192.168.1.1 and the default IP of the DSL gateway is 192.168.1.1 ... following steps to fix...
hardwire a PC to the Linksys router navagate to the webpage at http://192.168.1.1 (default username *BLANK* password: admin)
first setup all wireless options SSID: (choose something other than the default "linksys" so you can tell it from all the other linksys default systems in the world), WPA/WPA2 Encryption (so only people you know can get on)
after you set all that up then go back to the basic lan setup and change the address space from 192.168.1.1 to something else (e.g. 192.168.10.1, 192.168.21.1, or so fore)
Oct 15, 2010 | Linksys Wireless-G WRT54G Router
Hot to use LINKSYS Router as an alternate wireless acces point
this is not a wireless repeater i do beleive this is what want. You need a router or gateway with this function. look at this product http://www.linksysbycisco.com/US/en/products/WGA600N
Feb 20, 2009 | Linksys Wireless-G WRT54GS Router...
Which channel to chose
Channel 11 is the best channel to use to avoid any interference and have a much faster connection on your wireless network , if in case it wont work fine try using channel 1...
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Nat is moderate, cant access settings
You can assess the seting by typing it in while being conected by an eathernet cable to the router to adjust your settings. I hope this will help you fix the problem. Also do not for get to vote for this slusion.
Jan 04, 2009 | Linksys Wireless-N WRT150N Router
Unable to connect to the internet
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Dec 21, 2008 | Linksys Computers & Internet
Wireless channel
The ethernet cable connecting the router to the WAN doesn't require a channel. The channel setting is there for when laptop computer connects to the wireless router.
Channels 6 and 11 are mostly used in this scenario.
Does your wireless router communicate with your Internet provider wirelessly?
Hope this helps :) Please leave a rating. Thanks..
Nov 27, 2007 | Linksys Wireless-G WRT54GS Router...
Cannot access router webpage
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Jun 13, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
75 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
