Question about Whirlpool Calypso GVW9959K Top Load Washer
My GVW 9959K washer with Calypso wash motion quit working. The computerized dials started coming on by themselves and then stopped altogether. Unable to use washer.
  • mpp9278 Oct 09, 2010
    didn't work
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue is with the control panel going bad and needs to be replaced. However, before replacing the control panel you can try to take it apart and blow some air with the help of hair dryer so that if there is any moisture causing this issue, the air will blow it off. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 09, 2010
  • Rylee Smith
    Rylee Smith Oct 09, 2010
    Then as I said the control should be replaced.
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Timer dosent count down
HI, this is a simple fix here, you will need to replace the timer/control module. this will fix this issue. this specific device is ruined and, unable to initiate the wash cycle correctly due to circuit damage.
May 18, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
Whirlpool Calypso Washer starts then stops then starts and stops
With this Washer you are going to need the Factory Repair Manual. It will give you all the diagnostics and troubleshooting you need to find the issue and repair it. This are rather involved machines and you will need the guidance of the manual to better assist you on this. Especially when it comes to getting into the machine to replace the defective parts.
Download Whirlpool Calypso Washer Repair Manual
Good Luck
Jan 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer Stops/Starts when filling with water
Looks like part 8571359 the control electronics is out and guess what? Can only get through Sears and Whirlpool. This is why you cant get an error code, it isnt working well enough to choke one out. You know this is hard to say but a Oasis has its issues but at least it is still on market. I would if hubby is handy to find a used machine and pull the part. It is a chance but cheaper than 500 bucks to have a tech come out and fix.
Oct 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer
if youd like to open the calypso while running,Id assume to add clothing, hte machine will pause the cycle, and youll need to press the start/resume button, but it shouldn to have to restart from beginning of cycle
Mar 16, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
