Question about Refrigerators
Kenmore # 59651672100 refrig not cooling. freezer at 50 degrees, compressor is on but not cycling. already cleaned coils and fans are working. please help....thanks
kstfas
  • 75 Answers
SOURCE: doesn't cool
Hi, Yes, If the evaporator was not frozen over then I agree with you. The unit has lost its refrigerant charge. The only thing you can do is to have a licensed refrigeration man find the leak, repair it and recharge it or replace the refrigerator. If the evaporator is frozen over the defrost timer would be the problem. In this case, manually defrost it and it will be good for a few days until you get it replaced. kstfas
Posted on Sep 27, 2007
22yooper
  • 828 Answers
SOURCE: KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
Posted on Jun 03, 2008
kevin000
  • 1847 Answers
it should not be the compressor as the bottom is only not cooling.
Posted on Jun 23, 2008
zr800o1le
  • 19 Answers
SOURCE: Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
Posted on May 12, 2009
zr800o1le
  • 19 Answers
SOURCE: Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Freezer cools to 10 degrees, refrigerator cools to 50 degrees
check if the fan is working and you are circulating air efficiently. You may check on the coils at the freezer if there are ice formation. I would suggest to have the ice melted by unplugging it and ensuring that all parts are ice free. Clean the unit while at it.
Jul 15, 2009 | Refrigerators
May 12, 2009 | Refrigerators
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
