Question about Kenmore Dryers
Dryer wont dry
Dryer turn on but takes 2 or 3 cycles to dry clothes please help
  • 413 Answers
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Suggest going to Lowes and purchasing vent cleaning kit. Read instructions CAREFULLY. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
Posted on Jun 01, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer wont turn on
try to spin the inner drum. You could have a broken belt. if it spins really easy, that's probably what it is. There should be some resistance when you turn it.
Sep 08, 2012 | Whirlpool Dryers
Dryer takes 2 or 3 cycles to get clothes dry. how
they make a dryer vent cleaning kit found at Home Depot and Lowes
Dec 16, 2009 | Dryers
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Apr 14, 2009 | LG DLE3777 Electric Dryer
Dryer will not heat until after about 2-3 loads
I am online looking for an answer similar---our dryer doesn't heat....air comes out lukewarm and will not dry after 2-3 cycles.
Jan 02, 2009 | Whirlpool LER5636P Electric Dryer
My ge wont dry clothes it takes 2 hours
Check the exhaust duct. It's best to have a short run and no obstructions. It's also possible that a heating element could have been damaged in the move.
Dec 31, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
