Question about Kodak Easyshare M753 Digital Camera
Lens error 222 1,0,0??? - Kodak Easyshare M753 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 09, 2010
Always go back in and double check the PC life counter after the reset before F8. More than once the PC Life did not reset on the 1st attempt (other counters do reset 1st time) Take a quick look see.
Apr 11, 2014 | Konica Minolta Bizhub 222 Black and White...
Bizhub 222 how to open elevator section
Check the exit sensor on the elevator tray (paper exit unit).
Jan 01, 2013 | Konica Minolta Bizhub 222 Black and White...
99 blazer trouble code 222 and 226
go to www. autoelectronico.com translate the page and search for your error codes and fix it.
God bless you
Oct 13, 2012 | 1999 Chevrolet Blazer
Error code f-26-3
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit
if this is a bizhub 222 the toner density error code would be c2557
May 10, 2012 | Konica Minolta Bizhub 222 Black and White...
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
REGION CODE
Dear friend,
Try this method
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Jun 02, 2008 | Yamaha DVR-S150 DVD Player
I have a tascam CC 222 cassette compact disk player. sometimes I get a disk error message and cannot even play a compact disk. I there a reset or some other way to avoid this problem
Hi James
It is probably an optics problem causing you symptom. Does the machine consistanly not play the any discs, or just particular discs. Either the lens is dirty, or you have an failure occurring in the optic block. CD lens cleaner discs are generally a waste of time, so I would suggest that you remove the lid, and clean the laser lens. with a cotton bud moistened with windex, then gently polish off with a dry one to be sure no smears are left behind. See how this goes. The other common problem with not playing discs is a lazy spindle motor, identified by the disc atempting to spin, but not getting up to speed. Try cleaning the lens first, and let me know if you still have problems.
regards
Graeme
Apr 16, 2008 | Audio Players & Recorders
Sony dsc-f707
http://www.dcviews.com/press/Sony-Oct05.htm
http://online.wsj.com/public/article/SB113036700399480540-a19XaVrSzPcGNlv5Gmp_TgcLE_E_20061027.html
Digital Camera and Video Phone Number 1 800 222 7669 - it's automated, just say your model number, then "no" to accessories, then "no" to connection problems, then "picture" for ccd issues. Its that easy!
Dec 16, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
154 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
