Question about Microwave Ovens
My hotpoint ceramic hob switches on and off by itself displaying error message e00 and def
I HAVE A STOVES CERAMIC HOB 700CTH THAT IS SHOWING A FAULT 7A IS BEEPING AND FLASHING ON PLEASE CAN YOU HELP
The fault is on the PC board, capacitor C17. It can be replaced if you are handy with these things. Remove the hob and dismantle it to gain access to the PC board without turning it upside down. There are several screws which have to be removed, there are 13 spade connectors on the PC board, label these and remove them carefully. The capacitor has to be un-soldered and the new one fitted with the polarity the right way around. If this is not within your capabilities and you do not have the correct tools, have someone do it for you for a few dollars. A call-out for this fault could run into the $400 bracket and the part costs about $1.50.
Feb 08, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
Can I gaet a new glass top for a Diplomat HJA 1613 ceramic hob?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Bosch Microwave Ovens
Replacement ceramic hob element C00228943 for Creda EDCW60 has 4 connections on thermostat in place of 2 on old unit. Do you have circuit diagram for this replacement element please?
Sounds like it is the wrong element. I wouldn't like to advise further without seing it. Contact your supplier and ask for an explanation.
Dec 24, 2010 | Panasonic NN-P794SF Microwave Oven
Microwave Toaster Combe
The button may be stuck... try cleaning the display really well.
Oct 26, 2008 | Microwave Ovens
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
