Question about Microwave Ovens
Hearing sound from inside when it is switched on ,some time the glass turn table doesnot rotate
    Problem Solver:
  • 11 Answers
Either your turntable motor is going out or your turntable guide is not aligned properly or seated propertly when then glass is on top of it.
Posted on Oct 09, 2010
Replacing relay switch in electrolux high speed microwave oven
Sometimes a door latch or magnet closure is a problem. If the door fails to make proper contact when closed, the oven will not start. If the oven goes on and off, there is a disconnect and in some cases the rotating glass dish inside vibrates and causes a disconnect also.
Dec 18, 2013 | Electrolux ICON Microwave Combination Oven
Turn table wont turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 05, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Glass inside does not rotate now
The problem is typically the turntable motor, it is accessible by first disconnecting the power then removing the lower panel that houses the filters and lights. You will see a small device with 2 wires that looks similar to this
b162a2f.jpg The next most common thing to fail would be the coupling that attaches to this motor and sits inside the oven, you can take the glass tray out and lift the coupling, check for cracks or breaks, try running the microwave for a few seconds without the table and see if the coupling turns with the weight of the table on it. This may indicate a stripped coupling.
The 3rd component and most expensive to fail is the control itself, there is either a relay or diode on the control that sends a signal to the motor to turn. You should verify that you have power to the motor before replacing it.
I hope this helps
Apr 25, 2010 | GE XL1800 1100 Watts Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Dec 21, 2008 | Microwave Ovens
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Loud noise coming from turn table
I have the same problem my microwave is a kenmore this is the second one I've had and they both did it I solved the problem by re-seating the turn table however if you are skilled at taking things apart you can put a few drops of small motor lubricant on the spline it worked for me. good luck!
Nov 21, 2008 | Microwave Ovens
Microwave dish/tray rotates intermittently.
If the turntable is not turning, you will get hot spots and uneven heating.
You can get Samsung parts here.
Aug 03, 2008 | Microwave Ovens
Turn table has stopped working in sharp r-930cs
We have the service manual for that model and have uploaded it to our site for you here.
Chances are the coupler or motor is bad.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
