Question about KitchenAid KSSC42FMS Side by Side Refrigerator
I have a KitchenAid and it kept beeping every 2-5 minutes. I pressed he power button and it didn't turn off until a couple minutes. I turned it back on and the beeping stopped. BUT The fridge is not cool though pressed the cool button to bring temperature down and the freezer is fridged (ice cream solid). The Aquasense Filter Percent Left reads 99% while the freezer reads -23 and fridge 15...the numbers are flashing. The Over Temperature light is flashing, too.
2 Suggested Answers
SOURCE: Kitchenaid Icemaker with Aqua Sense is not working.
I had turned the water feed off on our Kitchen Aide Frig for several days while repairing another appliance in the kitchen and then discovered the aqua sense ice maker stopped working because it wasn't getting any water fed in, even after pressure was restored to the water line...appreciate your heads up as to the possibility of a frozen water feed...you helped me identify the problem
Nothing in the manual on this possibility, but without disconnecting power to the frig, I cleared off the top shelf in the freezer and warmed the area with a hair dryer..on our large side by side, it appears that the water is fed to our ice maker from the top of the frig on the right side...I warmed the area for three 5 minute periods...about 10 - 15 minutes apart...I noticed water starting to leak into the tray (I assume from the melting) and carefully sponged it out so I could gauge the success of the melting...
I am not sure if it made a difference, but half way thru the process I also powered the machine off (from the controls on the refrig side) as I wasn't sure if a reset cycle was necessary....about an hour later, the machine self feeder filled up the tray and it is once again making ice...
I would caution going slowly with the heat and concentrated hair dryer so as not to damage any of the plastic...other than that, this was pretty easy..
Posted on Jan 04, 2010
Kssc42qms01 side-by-side. About a month ago refridgerator side was too warm. Removed top grill and cleaned coils. All was fine until today. High temp warning (beep) and both compartments now reading...
I just checked my sheets on this unit, this unit has to be turn off first, turn it back on and can only enter the service mode within 13 second after power up. Hold the filter rest then power button for three second. I hope this helps. Good Luck
Oct 01, 2013 | KitchenAid Refrigerators
Hello, my MW511 Fiisher and Paykel top loader washer is not working, the lid locked light keeps flashing before the spin cycle and it keeps beeping and never starts the spin cycle... what can be wrong? I...
Hi - you may have somehow put the machine into data mode - its either that or the door lock itself has malfunctioned - the only other logical one is thw controller module.
I'm assuming its a Phase 6 - try this - press/hold wash temp & power button until u get 2 beeps & lights up - release buttons...
NOW IMPORTANT - be careful you are in memory system of the controller -
1. press start/pause to unlock/lock & toggle that lid locked lights - check default is off.
2. I think its either advance or regular to turn pump on/off.
3. try a few buttons see what happens - THEN
turn off at the wall & try it again, if it still doesn't work then we may have a more sinister problem which will require correct testing of the components.
This will require a thorough knowledge of how to interpret the test results, to nail the culprit.
Sorry cannot help further...
Jun 30, 2011 | Fisher and Paykel Washing Machines
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
H owdo you clean the machine using the tablet ? Thanks
  1. Turn machine off.
  2. remove group head (portafilter)
  3. place single or dual cup filter in group head.
  4. place rubber bung in group head.
  5. place one tablet in space in bung.
  6. replace group head in machine.
  7. This is where the instructions lead you astray.
  8. DO NOT PRESS 1 & 2 CUP BUTTONS SIMULTANEOUSLY WITH POWER BUTTON.
  9. Press & hold 1 & 2 cup buttons simultaneously, on their own.
  10. Now press the power button while still holding the 1 & 2 cup buttons.
  11. Cleaning cycle will start, and will take around 5 mins to complete. Book says it will beep 3 times when finished haven't heard this yet. Just wait a couple of minutes extra and all should be well.
  12. Clean me light should be out and tablet disolved if not repeat steps again until tablet disolves.
Dec 08, 2010 | Breville Fresca BES860 2Cup Coffee Maker
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Playstation3
Becoz ur hard disc got corrupted ! But don't worry, U need swith on the PS3 & touch hold both the "Eject" & "Power/Reset" button for 20 secs or until a triple beep sound. It will restart the PS3 with a Message " Press X Button to restore the corrupted data ".. Enjoy.. !! =D
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
Nov 29, 2008 | Nike Triax Fly WK0006 009 Watch
PS3 Freezes on startup
ok here is how you do it i finally fixed my ps3 by doing some easy steps
1.have the ps3 off with the red light on and put your finger on it until it turns on and the off again
2.take off your finger and then put it on again on the power touch button until you hear two beeps
3.it will ask you to connect a usb cable from your controller to the ps3 do that
4.after that go to the second one that says restore data or memory
do those steps and your ps3 will start working in no time
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
KitchenAid KSSC42FMS Side by Side Refrigerator Logo
53 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
