Question about Radio Communications
Radio code problem
My battery head lost contact,and on fixing it back my radio was asking for the code which i entered.but this makes continuous tone and automatically switches off after some minutes requesting the code again.please what can i do
Just dont use it
Posted on Jun 07, 2008
How do i enter radio code for 2009 honda civic
I just had this happen today when I jump started my car due to leaving my head lights on. Call the honda dealership you got your car from, or if you bought it privately just call a honda dealership. They will tell you to press and hold the pre-set buttons 2 & 6 and it will give you a number, they will type it into their computer and they will be able to give you the code. You have to use the pre-set buttons on the radio to enter the code. That will fix the problem... If you already entered to many wrong codes it will not allow you to enter anymore... You will have to either wait an hour and then it will reset again and let you enter the code or you can disconnect the battery for 5-10 mins, reconnect it and then the radio will reset and ask you for the code again. Good luck guys!
Jan 01, 2012 | 2009 Honda Civic
We purchasedn 3 bpr 40 and we justed ordered another, when we turn the bpr on to the channel of the 3 others that are in use, we just get a low continual tone, i tried a radio check on channel 1 with no...
Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
Sep 14, 2011 | Motorola Mag One BPR40 Two Way Radio
Hey there i have a 1997 BMW 328i and i changed my battery n when i started the car up my radio said code wait andd now i cant get rid of it please help me fix this. thank you ...
Hi chris,
Code wait is part of the built in anti-theft system BMW has for the radio. The ignition must remain in the on position for 1 continuous hour. Usually rush hour traffic does the trick. You will need the radio code to enter into the radio after it displays "CODE". just enter the code according to the buttons listed 1-6. ie if it ask for 13556, just enter the digits in that sequence. Make sure you have the correct code. If 3 unsuccessful consecutive entries are made, you will have to wait another hour.
Jun 28, 2011 | 1997 BMW 328
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
I removed The Battery of my car then the radio asked for CODE How can I fix it? My Car Model is Jaguar S-Type 2004
Simple contact you local Jag dealership and ask them, they will need the VIN No and there is a small charge. Then follow the instructions on to enter code.
Aug 09, 2010 | 2003 Jaguar S-Type
Battery went flat so need radio code for renault megane
With the car, comes a plastic "infocard" with the radio and alarm codes. If you lost the card or didn't receive it with the purchase, you can ask for the code to the radio manufacturer, they'll ask you the serial number of the radio and the car and they'll send you the code.
Jan 12, 2010 | Car Audio & Video
The battery died on my 2001 eclipse, now the radio only says ''off''?
This is the anti-theft device on your factory radio. When the battery died, the radio thought it had been removed from your car and went into anti-theft mode. When you turned the car back on, the radio should have read "CODE" on the display, at which point you need to enter the factory anti-theft code. After 3 failed attempts at entering the code, it will simply read "OFF" and the radio is locked.
At this point:
- find your factory anti-theft code - it should be in your owner's manual, or you can contact a dealer to retrieve it
- turn the key to the ACC position (radio and accessories on, but engine is off)
- turn on the radio so the display reads "OFF"
- let the car sit for 1 hour
- radio will turn off automatically and reset
- turn the radio on again, and it should read "CODE"
- enter the factory anti-theft code
Make sure you have the code before starting the procedure. To enter the code, use the radio preset buttons. For example, if your code is "4321", hit Preset #1 button four times, Preset #2 three times, Preset #3 two times, and Preset #4 one time. Then hit the "Tape" or "CD" button. Radio should now be unlocked.
Sep 13, 2009 | 2001 Mitsubishi Eclipse
Radio Communications Logo
53 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
