Question about Microwave Ovens
I have a Indesit DI 620 dishwasher that wont empty its water and with an error code of no 2 and 4 flashing rapidly, what can this be please ?
    Problem Solver:
  • 11 Answers
You should consult your owners manual for the error code description in the back under "troubleshooting". The obvious problem is that you are not rinsing your dishes enough and the bottom drain is clogged and needs to be cleaned out. The food will clog the hole and back it up.
Posted on Oct 09, 2010
Why wont My Daewoo DWF-750 washing machine not empty water automatically
You've probably got some debris in the pump, or blocking the pump inlet. If you can do this without making a mess (or shocking yourself,) try backflushing the drain hose.
May 06, 2014 | Microwave Ovens
Door Open light flashes and relay clicks rapidly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, please post a new help request with the full model number from the tag in or on the unit.
Apr 29, 2013 | Whirlpool WMH1163XVS Microwave Oven
KithenAid model KUDSo1DL wont operate, clean green light flashes non stop
This is a issue with the way the water is moving & or heating in the unit. There should be a tech mini manual behind the motor kick panel. The manual describs the failure and it's correction. Depending the the model year & run / revision code, this error could be caused by low water level, a bad thermistor, the control board not sensing inputs, bad heater or door interlock switch issues. attached is a couple of help sheets. They are general in scope.
Mar 27, 2012 | KitchenAid Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Dishwasher controll panel not working, clean water in tud not . Replaced thermal fuse (used existing wire ,not from kit) worked fine. Few days water in tud ,pushed drain , water went away.Recurred again...
    Yes it is very possible that the water inlet valve needs replacing. What is the make and model # of the dishwasher in question here?
    Please just reply to my answer when you get a chance and I will get right back with you.
    Thanks
    Tim
    Nov 03, 2010 | Microwave Ovens
    GE built-in dishwasher M/N GSD3210Z02AA does not pump out all water. Usually 1/2" of water remains in the sump well.
    Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
    Dishwasher Problems - Water will not drain out
    heatman101
    Oct 07, 2010 | Microwave Ovens
    My Kenwood Dishwasher shows an E4 error code
    Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
    http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
    You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
    Aug 25, 2010 | Microwave Ovens
    Wash cycle wont finish start button does an 8 flash cycle
    Hi, these machines get corrosion in the door safety switch. I would start there.
    A little cleaning of the contacts might get that machine going. How about a repair manual?
    I have a few:
    http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
    Take care
    Apr 11, 2010 | Microwave Ovens
    I have an error code on my new LG LDF 6920st dishwasher. It runs for about 10 minutes and then dings and flasher LE
    I would suggest calling the seller or distributor and having this unit replaced.
    This error is not part of the consumer repair area and should only be done in A workshop here are two preevious ownrs experiences
    1)
    LE ERROR CODE
    YOUR MOTOR RING CAME APRAT
    THE UNIT EMPTIES AND REFILLS AND STOPS AT WHEN IT TRYS TO WASH I had to take the unit apart from the inside to comferm the motor is stuck. remove the racks the spinner in the bottom, the screen assy (1 foot in dia.) the wheel of pump with left hand threads, make sure it is unplugged, try to spin the garbage disspser blade. if it has trouble spinning then, pull out dish washer unit and flip over and remove the cover on botom and the motor and ground wire. good luck. i have had to replace mine twice now!
    2)
    I had the same problem and was told it was the motor. Well, it wasn't the motor. Take the front panel off & look at the wiring harness. There was a wire broken, not to mention the insulation was in the wrong place. It should be between the inside wall (dishwasher tub) and the wiring harness this way the wires wont get hot and break. Simple fix but, I would have never thought to take the door apart.
    This unit is under warranty and should be attended to by the technicla support. LG are not good quality at any time, now made in Korea as cheaply as possible.
    Please rate my help++++Thanks for using FIXYA
    Nov 16, 2009 | Microwave Ovens
    Microwave Ovens Logo
    105 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
