Question about LG 32LC51 32 in. HD-Ready LCD TV
Tv turns off after 8 to 10 minutes of being turned on. If you try to turn it on again it shut off immediatly. If stays off for about half an hour it will then stay on for a few minutes then turn off again.
  • LG Master
  • 17,129 Answers
Possible fault is in the power supply or the main board power drive circuits. You must check for components that are heating up and losing off the connection due to drying of solder.
So if your are able to assist with some soldering please try to open set, check on the power supply circuit and the main board. Solder all suspected joints, connectors and IC pins.
Please make sure that the main capacitors are discharged off before touching or soldering the board . You can also allow time for discharge but make a test with a multimeter before you touch the circuit.
Also you can allow cooling of any heating sections to see if the set continues to go on. If so check the circuit in question.
Posted on Oct 09, 2010
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Picture goes out, sound stays on
According the information I believe your backlight might went out. call 323-767-6030 I will go through with you for your tv.
Dec 14, 2008 | Astar LTV-3201 32 in. LCD Television
Maytag refrigerater
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
May 16, 2008 | Maytag Refrigerators
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
The flashibg red light
John, I do not know of a code, but it is a good idea in the design to have several goes at starting a circuit, before completely shutting it down. Oscillators are supposed to self start due to noise generated. Some electronic circuits require a reset pulse to be generated before the start up is allowed. The reset circuit may not be generated if the set is turned on again too soon, so it will stay in standby. This may normally be a few minutes to 30 minutes so it seems something in your set is faulty and could get worse. Try a test run with the back off and clean it out of dust with a long brush to keep it cooler. Make sure little fingers cannot get near it. Look to see if anything is obviously overheating.
Oct 21, 2006 | Thomson 24WK25U 24" TV
LG 32LC51 32 in. HD-Ready LCD TV Logo
401 people viewed this question
Computer Repairing
Computer Repairing
