Question about Yamaha RX-V661 Receiver
CANT START WHY THE MOTORBIKE CANT START IF LEAVE IT UNTIL THE NEXT DAY?
    Brigadier General:
  • 6,966 Answers
Most bikes (and gasoline feed engines for that matter) would require two crucial elements to start/run: 1) fuel and 2) ignition. A hard starting engine then could be caused by:
1. fuel starvation - there is no fuel in the carbs (or high pressure fuel pump for injected). This could be brought about by the fuel tank's valve which will only allow fuel to flow through if there is a vacuum, the engine is already running. In some models, there is a setting on the fuel valve ON, RES and PRI. On is just that one but requires the vacuum from the intake manifold, RES is for reserve, same as ON except that it the inlet sits lower inside the tank but also requires vacuum. PRI is ON and will allow fuel to flow even without vacuum. Before starting the bike, moved the fuel valve control to PRI if the Yamaha has one. Additional on cold start, putting on CHOKE to about 3/4 up would also enrich the fuel/air mixture making an easier start.
2. Ignition - At every engine start, the battery supplies power to the starter motor and to the ignition system. In some instances when the battery is going weak, the starter motor will gobble up most if not all of the power output of the battery leaving nothing for the ignition system to use. This is especially evident if the bike was used at night with the lights open and the bike did not have a chance to re-charge its battery before switched off. Starting on the next morning would be on a bike with its battery partially depleted. In some instances, the charging system may be at fault if and when it fails to deliver sufficient charging to the battery. Often causes are corroded or loose connection or even a a partially defective voltage regulator.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 30, 2008
Cranks and then leaves u stranded
if it's not a battery problem. Replace your crank
Jan 02, 2014 | 1998 GMC Jimmy
Fuse keep blowing on ccm 404 ds motorbike
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue, please visit the websites below. Good luck and have a nice day.CCM Motorcycle Specifications
CCM 404 DS Trail 2007 technical specifications
http://fullmanuals.com/year/2007/?page=31
http://www.ccmspares.co.uk/
http://manuals.no-ip.ca/mek/C/ccm-404ds-supermoto-2008-super-motard-single-cylinder-users-manual.pdf
Apr 19, 2013 | 2007 CCM 404 DS Moto
I have a 54 inch cut Club Cadet Riding lawnmower. It is 4 years old. When it is running it is a good machine. but I am having problems starting it after not using it for a while. I put gasoline...
roght when you leave it for the winter drain the tank ,also on the bottom of the carb is a drain as well so empty it all when stored ,Now what to do now without stripping the carb is to to use the fill pipe to the carb make sure you drain it first and then spray brake and clutch cleaner down the filler pipe so the carb gets filled with this leave overnight and then open the drain plug on the carb and repaet and then try a day or so later ,cant guarantee it will work but it normally works on old VW camper van (carb) and my motorbike .
Nov 07, 2011 | Cub Cadet Street Sign- tractor lawn riding...
91 nissan stanza - car will not start, tried serval times and it just click and the turn the key to start. It will not even turn the starter. Tried the next day and it cranked immediately. It has done...
Your starter solenoid is worn and going bad. Have the starter replaced and it should start every time after that. I had the same car, with the same problem. Change the starter.
Dec 28, 2010 | Nissan Stanza Cars & Trucks
Starting problem one its fine drive couple hours shut it of come back nothing leave it till the next day it starts, just rebuilt engine its some type of element ect just cant figure this out
sounds like the fuel pump. my friend had same problem,,bad ground caused fuel pump to over heat..resecured and cleaned ground and problem fixed
Jun 06, 2010 | 1986 Toyota Pickup 4WD
New starter, alt, and battery but battery drains over night boost car and runs all day next day no start. manual transmission so i roll down hill and it starts but not when battery is totally dead
there are not a lot of computers that could be causing the drain, so baring any aftermarket accessories you should start searching for an indirect short to power
prop hood and leave the doors open... this is important because you do not want to wake the computers once you start your test
next, unplug the negative battery cable and insert a DVOM in series
drain should be less than 80mA after 30-90 minutes
if drain is higher, start pulling fuses until the drain is isolated
Apr 06, 2010 | 1987 Ford Escort
Motorbike problems
zx7r ran 10miles no problems stopped a junction and sounded if on 2 cylinders and wouldnt rev. Got her home on back of a trailer still starting but same problem, next day would nt start.She gets a spark and fuel to the carbs.Help.
Dec 17, 2009 | 2005 Yamaha FZ6 Fazer
Motorbike wont start after running engine kawasaki kx 250 if i ride my bike for 2 minutes or 50 minutes when ishut down the engine it will not start again until i clean the spark plug
possible bad rings allowing excessive oil seep up and wash spark out on next fire. do a compression check, ck for proper spark, and fuel....hope this helps
Sep 13, 2009 | 2003 kawasaki KX 250
Yamaha RX-V661 Receiver Logo
203 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
