Question about LG WM-1290FHB Front Load Washer
I have an error code of SE on my LG Intellowasher. What does it mean?
SOURCE: LG Intellowasher - CL in led code whats wrong?
had this prob too. took me a while to work out. CL is Child Lock... hold down 'Rince' and 'Prewash' buttons at the same time to unlock.
Posted on Aug 13, 2007
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
huuum
  • 750 Answers
SOURCE: i have a lg intellowasher
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Send me the model # and I'll see if I can send you the user guide download location.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
  • 412 Answers
SOURCE: What does SE mean on my LG Intellowasher 7kg WE-8074FHB display
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Posted on Mar 22, 2009
jan mczeal
  • 632 Answers
SOURCE: What does dE flashing on the LG intellowasher
It is an indication of door error. The door is either not shutting, locking or opening.
  1. Turn off the unit and unplug it for 5 minutes then replug and turn it on. If the problem persists, proceed below.
  2. Check the door latch
  3. Check if there is something that is caught in the door and prevent it to shut properly.Remove any stuck items that might push the door latch up or down during operation.
  4. Check if the door or gasket is damaged. Damaged door or gasket will prevent the door from latching or locking properly. Replace damaged gasket. Dis-aligned door prevents the door latch to lock properly.
  5. Check the door latch for any damage. Replace if defective.
Posted on Nov 04, 2009
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
I need to know what an E1 error message is on a LG Intellowasher model WD8026C is please.
Did you find the service manual located inside the unit. This will explain what all the error codes mean.
Sep 25, 2011 | Washing Machines
What does OE mean on my LG intellowasher frontloader
its a open door error its because the door is not closing all the way.
Dec 27, 2010 | LG Washing Machines
I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
Aug 16, 2010 | LG WD-1080FD Front Load Washer
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
Main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
May 30, 2010 | LG WD-16115FD Front Load Washer
Good Luck!!
Mar 22, 2009 | LG Washing Machines
LG intello WM12235
SE error code means a communication problem between the display controls and the main control board.  You will need a qualified LG technician to locate and repair the problem.
Jun 09, 2008 | LG WM-2277HW Front Load Washer
LG WM-1290FHB Front Load Washer Logo
465 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
