Hi my monitor on my laptop has recently started flickering and going dim and acting like it's going out. Can this be fixed or what is wrong. I just had knee replacement and on pain meds but yesterday and tonite , at least 3 different times it's like i got a shock of electricity that went through my body.
  • Chris Hingee
    Chris Hingee Oct 09, 2010
    Where were you getting an electric shock form your laptop?
    There could be a sever electrical problem with your laptop.
  • 60 Answers
If your laptop monitor is going out, replacing the LCD Inverter or the LCD screen is a bit tedious but possible. If you are not comfortable in doing either of these, I would suggest going to a local computer repair shop.
Posted on Oct 09, 2010
Laptop screen flickers
Probably the flex cable on your laptop is damage.
try to contact your nearest service center shop to check on it.
Dec 03, 2011 | HP Compaq Presario V5000Z Notebook
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Dim monitar with flickering screen
The problem can be caused by 1 of 2 things either your power supply is going out or the backlight bulbs are going out. The most likely cause is the power supply. If you are willing to do a little soldering you should be able to do the repair. If you go to our web site at: www.ccl-la.com/badcaps.htm We have a section on monitor repair. Look under the Samsung 930B it is the same as your monitor.
If you don't want to do it yourself we do offer a repair service, email me if you are in need of that.
I hope this helps.
Buddy
Aug 05, 2009 | Computers & Internet
HP Pavilion Entertainment Laptop Monitor flickers black
If the laptop is under a year old it could still be under warranty and if so I would get it repaired under warranty.
OTHERWISE
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop screen flickers and goes off .
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 13, 2009 | Sony VAIO VGN-C140G/B Notebook
Screen Flickers
Hi I've recently fixed 2 laptops with a very similar error, neither of which were Hewlett Packard Compaq's. That aside its a fairly common error and that is a loose connection. Unless you've a lot of experience in dismantling and reassembling laptops, I strongly reccomend taking it to an experienced technician.
I hope this helps
Apr 07, 2009 | HP Compaq Presario CQ50-110US Laptop
Computer Monitor is dim
Time for a new flat screen monitor...The power supply is on it's last legs.
Apr 03, 2009 | Toshiba Tekbright 15" CRT Monitor
"Flickering" screen
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 15, 2009 | Toshiba Satellite A105 Notebook
Backlight is acting like a bad flour. tube .. everthing else OK
Normaly the backlights have a life of around 40k hours of working.
If your monitor is 3-4 years ,the backlight tube/s could be defective.Your description seems to indicate tube aging.
It's possible to replace the tube but needs a good amount of technical skill.
Do write if you need more help,Please indicate make exact model no etc.
Samir
Mar 22, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
