Question about Dewalt Audio Players & Recorders
I have a Dewalt radio (Dw911) that will only play off the battery, not the power cord. I have checked both fuses and found both to be good. It sounds as if this is a common issue but I have found no solution.
    Problem Solver:
  • 5 Answers
Mine had the same problem .Try swapping the fuses. Although the fuse looked good mine was bad. Easy fix I hope. Going to auto parts store for new ones.
Posted on Nov 24, 2010
  • 1 more comment
  • Paul Humberstone Jan 19, 2011
    How do you actually take it apart?
    Read somewhere that there is 18 screws on front 2 on back.
    Can someone point them out to me.
  • Paynz Jan 19, 2011
    There are 8 screws around the outer part of the radio. Remove them and tap on the sides . It takes a little persuading but it eventually pops apart .Be careful as the speaker wires hold the 2 pieces together. Good luck .
  • b_reeve Apr 08, 2017
    May be the 1 amp fuse on the power board, BUT a failed transformer is at least as likely. Determine this by measuring the AC voltage on the two yellow wires going to the power board. Reports from measuring the secondary output of transformers in working units suggest 14 volt AC output. Something rated for an amp would probably be good (consider the size of the fuse)
Dc011 radio works with battery but wont work when plugged in what could it be
Sounds like the mains transformer has gone. That is what reduces the mains outlet power of 110 volt to that of the batteries.
You could check the power cord though for 110 volts at the end.
Oct 31, 2015 | Dewalt DC011 AM/FM Radio
Dewalt radio dw911 will play on mains but nothing with battery only
If you pull of the back cover you will find two small fuses near power supply, one of these allows power from battery pack, check with voltmeter for open circuit, I take it that it is not just one battery it does this with.
Nov 27, 2007 | Audio Players & Recorders
My dewalt dw911 radio/charger works on either mains or battery but wont charge a battery and blows an internal fuse when both are used together
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Oct 24, 2009 | Dewalt DC011 AM/FM Radio
Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Aug 06, 2009 | Dewalt DC011 AM/FM Radio
DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
Feb 18, 2009 | Dewalt DC011 AM/FM Radio
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Dewalt dw911 radio
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP) great now!! Many thanks to all of you who posted suggestions on this great website!!
Jun 05, 2008 | Dewalt DC011 AM/FM Radio
Dewalt radio dw911
Have you changed the AA Batteries, this is often the fault, when they are flat they lock the radio out. HHM Dewalt Service
Nov 27, 2007 | Dewalt DC011 AM/FM Radio
2 screws sunk in at the back left and right. no need to remove speaker screws.
Oct 27, 2007 | Dewalt DC011 AM/FM Radio
802 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
