Question about Canon imageRUNNER 4570 Copier
My copier machine ir 4570 always damaged film when it out of 30000 -40000 copies i were explaned the copier expert he called me to bring orignal greec but not avalibal in nepal. what can i do ?
  • Canon Expert
  • 1,326 Answers
Please explain more about what you are tring to do? Are you asking why is the fuser film only lasting 30k to 40k copies? If so, it depends on what kind of paper you run in the copier. Also, it is not designed to last for ever. I think I've answered your question?
Posted on Oct 10, 2010
Canon ir 4570 paper jaming in heater section what can i do
check your outlet delivery guide or whether your fuser film rotation
Nov 05, 2014 | Canon ImageRunner 4570 | IR4570 |
Canon ir 4570
Fuser unit / fixing unit problem check whether fuser sleeve is damaged if yes change it or apply fuser oil and white grease on it for smooth rotation....
Jun 24, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
I change fixing film still problem e000000-0001 what can I do? canon Ir 4570
you may have forgotten to tight connector screw of heating element.check it if it is ok then check the continuity of heater element with multimeter, if it is not showing continuity replace it.
Mar 02, 2011 | Canon imageRUNNER 4570 Copier
While copying, system error E007 appears and machine stops immediately. As machine stops copying paper also get stuck.
E007 Fixing film rotation error
Inspect fixing film for damages
Main Cause/Symptom: Fixing film sensor failure
Countermeasure:
- Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Feb 02, 2011 | Canon iR 2016i Black and White Copier
From where can i get genuine canon ir 4570 fuser film
Hello
The genuine parts is available to authorized Cannon Service Center or you can buy online from here http://www.precisionroller.com/fixing-film-assemblies---units-for-canon-imagerunner-4570/details_35006.html
Hope this helps
Jan 26, 2011 | Office Equipment & Supplies
Canon iR 4570 Error code E00007-0000
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech.
May 19, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Error
E000007-0000 code is Fixing Film error.
FM2-3346-000
1 FIXING FILM ASSEMBLY 120V
FM2-3353-000
1 FIXING FILM ASSEMBLY 230V EXCEPT CN
FM2-3329-000
1 FIXING FILM ASSEMBLY 230V CN
Sep 11, 2009 | Canon iR 2016i Black and White Copier
Canon imageRUNNER 4570 Copier Logo
111 people viewed this question
old marine
old marine
