When set to cool one side ends up blowing warm to hot air?
  • talknitup Oct 09, 2010
    hi i have a NEC split system a/c, when i set it to cool eventually it will bloww warm - hot air from one side into room being cooled. pls help!
    NEC RSH-6847, cool cap. 6800w, heat cap. 7000w, 3100w/14.4A rated, T1, db814. When household NEC split system air conditioner is set to cool eventually one side will blow warm - hot air?
  • 22,326 Answers
Needs regassing thats all ,gas is low and its added by weight
Posted on Oct 09, 2010
    Top Expert:
  • Heating & Co... Master
  • 79,189 Answers
What kind of AC system is this? if it is in a car or truck need the year, the make and the model, automatic temperature control AC or manual AC?
    Genius:
  • 1,478 Answers
If one side of the air conditioner doesn't seem cool, it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following: Air damper Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit. Back cover During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first. Condensing coils The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
Take care.
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Jan 21, 2016 | Cars & Trucks
Hot air from drivers side cool air from passenger side
Driver's side blows hot air; passenger side cold air - Hyundai ...
www.hyundai-forums.com/.../294097-drivers-side-blows-hot-air%3B-pa...
Jul 29, 2014 - 3 posts - ‎3 authors I soon noticed that the driver's side blows warm air and the passenger side blowscold air as it should. No amount of adjusting the temp control ...
Hot air on driver side vents - Cold on passenger side - Page 3 ...
www.odyclub.com/.../46646-hot-air-driver-side-vents-cold-passenger-si...
May 9, 2012 - 16 posts - ‎10 authors I have a 2009 EXL Odyssey that just is doing the same thing (warm air on drivers side, cold on passenger). I checked freon levels and ...
Oct 15, 2015 | 2009 Hyundai Sonata
Honeywell 97-4118/5-89
probably low on freon. i assume compressor is running?
Jan 25, 2014 | Honeywell ER150B Air Conditioner
Heater blowing warm and cool air
Try flushing the cooling system. The heater core us probably clogged. A flush may clean it out. Good luck.
Nov 18, 2013 | 1994 Oldsmobile Ninety Eight Regency
2003 Ford Explorer XLT Air Conditioning vents blow hot and cold
It sounds like the control motor switching from hot to cold is stuck halfway in between the two temp settings. You will have to take it down and replace it, it is mounted under dash passenger side near the blower motor.
Sep 09, 2009 | 1996 Ford Explorer
My climate control starts blowing hot air while a/c is on
Make sure you have fully charged AC sytem first, if so Im sorry to tell you this but this is a difficult deal.you may not be able to correct this without taking it to a repair shop with gm scan tool. Reason being the actuators for the hvac that most likely are malfunctioning from either them or another component being bad , require recalibration.The other reason would be the body control module related.It would have to be scanned for U codes which can effect the hvac control.Sorry but thats what I know.
Sep 06, 2009 | 2003 GMC Sierra 2500HD
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Aug 29, 2009 | 2003 Hummer H2
A/c and heater
Is it leaking antefreeze?
The thermostat might be gone or needs a bigger thermostat
It could be a vaccum leak for the drivers side blowing cool air and the passenger side blowing warm air
Does it have dual air control switches one for drivers side and one for passengers side?
Oct 28, 2008 | 2003 Pontiac Grand Prix
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
