Question about Gateway FPD2275W LCD Monitor
MONITOR CLEANING HI, MY MONITOR IS AN LCD SCREEN, ON THAT SOME DOTS ARE THERE CAN U TELL ME HOW TO CLEAN LCD SCREEN? CAN I DID IT WITH WATER OR PLEASE SUGGEST ME IS THERE ANY FLUID AVAILABLE IN THE MARKET?
    Sergeant:
  • 458 Answers
You can buy screen cleaner at just about any computer store. I would not use anything harsh. You can use water, but be sure to dry to good and do not use much at all. Do not scrub it hard either.
Posted on May 30, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
How to clean screen
I dont know which type you have but here is how to clean either:
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don't ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
LCD monitors are often called flat panel monitors because they are flat and thin. These are the types of screens that are used in most laptop computers, and they are also becoming very popular for desktop computers. LCD screens are softer than CRT glass screens, so they require some extra tender loving care. Keep your fingers and sharp objects away from these screens since they are susceptible to damage and scratches.
Use a soft dry cotton cloth to remove fingerprints and smudges from the screen. If this does not completely remove the dirt and splotches, use a small amount of isopropyl alcohol on the cleaning cloth that has been dampened with water. (A small amount of vinegar can be substituted for the isopropyl alcohol.) Again, spray the liquid on the cloth and never directly onto the screen. Do not use paper towels on an LCD screen as they can scratch the screen. Never use ammonia, ammonia-based cleaners, or strong cleaners which can cause the surface to yellow and become brittle.
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don't pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Nov 01, 2012 | AOC e943Fwsk 18.5" Widescreen LED Monitor
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me easy procedure of cleaning my ViewSonic LCD Monitor screen. email: amdesh1@gmail.com
Hi
Time Required:
Cleaning a flat screen (LCD) monitor usually takes less than 5 minutes Here's How:
  1. Turn off the monitor. If the screen is dark, it will be easier to see the areas that are dirty or oily.
  2. Use a dry, soft cloth and very gently wipe the screen. A great choice would be the microfiber type of cloth used to clean eyeglasses.
    See Tip #1 below for kinds of cloths to avoid.
  3. If the dry cloth did not completely remove the dirt or oil, do not press harder in an attempt to scrub it off.
    Pushing directly on the LCD screen can often cause pixels to burn out.
  4. If necessary, dampen the cloth with distilled water or with an equal ratio of distilled water to white vinegar.
    Many companies also sell small spray bottles of special cleaner for flat screen monitors but the vinegar mixture is usually just as effective.
    See Tip #2 below for products to avoid.
  5. The plastic edge that surrounds the screen can be cleaned with any multipurpose cleaner but take care to avoid contact with the screen itself.
Tips:
  1. Avoid using paper towels, toilet paper, tissue paper, or something like your shirt to wipe the LCD screen. These non-ultrasoft materials can scratch the screen.
  2. Avoid cleaning products that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the materials that the LCD screen is made of which could yellow the screen or cause other kinds of damage.
  3. Never spray liquid directly on the LCD screen or it could run inside the monitor and cause damage.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me a procedure how can I clean my ViewSonic LCD Monitor screen.
To clean the monitor first turn it off then use something like a microfiber cloth or something that is not abrasive to clean the surface. Don't press down excessively this can cause damage to the monitor. If that does'nt get all the fingerprints and such off a solution of distilled water with a little
white vinegar will do fine just use it lightly and don't drown the monitor. Make sure to use just enough solution to lightly dampen the monitor and not so much as to run down the monitor and
risk getting inside where the circuits are.
WHAT IS BEST METHOD TO CLEAN THE MONITOR SCREEN?
Hi Good day!!
Here's How:
1.Turn off the monitor. If the screen is dark, it will be easier to see the areas that are dirty or oily.
2.Use a dry, soft cloth and very gently wipe the screen. A great choice would be the microfiber type of cloth used to clean eyeglasses.
3.If the dry cloth did not completely remove the dirt or oil, do not press harder in an attempt to scrub it off.
4 If necessary, dampen the cloth with distilled water or with an equal ratio of distilled water to white vinegar.
5.The plastic edge that surrounds the screen can be cleaned with any multipurpose cleaner but take care to avoid contact with the screen itself.
Tips:
Oct 27, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
How to clean LCD monitor?
Monitor wiping cloths. You can get then at any Wal-Mart, Staples, Frye's, etc.
Mar 28, 2010 | HP Compaq Presario CQ50-110US Laptop
Cleaning lcd monitor screen
use any soft clothe with liitle bit wet and wipe on screen.and leave it for 10 minutes .
Sep 08, 2009 | Computers & Internet
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
LCD screen...unsure
Warm water on a lint free cloth and don't rub too hard. Not too much water either ....just needs to be damp ...
Dec 31, 2008 | BenQ FP71G 17" LCD Monitor
Cleaning
Buy an cleaning kit with cleaning solution, and clean the display very carefully. If you apply too muck pressure you can damage the LCD display.
See also:
How to Properly Clean your LCD Screen
How to Clean an LCD Screen
How To Clean A Flat Screen Monitor
Dec 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cleaning monitor
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don’t ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don’t pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Jan 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
