Question about JVC Cybercam GR-DX75 Mini DV Digital Camcorder
JVC DIGITAL VIDEO CAMERA GR-D23EK
EVERY TIME I TRY TO RECORD IT COMES UP WITH THE MESSAGE REMOVE LENSE CAP CAN U HELP PLEASE
  • Anonymous Jul 11, 2008
    The same problem with JVD GR-D23EK. 'Lenscap' error shows when it starts and nothing more ...
  • Anonymous Nov 14, 2008
    i have the same problem !! annoying !!
This is prob fault of CCD. JVC know this a problem and will offer a repair prob free of charge up to dec 2008
Posted on Oct 20, 2008
  • 34 Answers
Replace ccd base assy. Part no. LYH-30446-002A-S
Posted on Sep 05, 2008
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
Unable to record
I was using my voice Digital Recorder VN-6200PC. I was recording a my lesson when the screen shows formatting, I immediately took out the battery as not to lose any data, because I was taping and it began to format and I lose the data I was recording. So this time I remove the battery. However when I put back the battery it began to say imput blocked. Please help?
Jul 18, 2010 | Olympus VN6200 Digital Voice Recorder
JVC COMPACT VHS CAMCORDER MODEL NO. GR-SXM250U
I cant find a solution but causes may be :
1. Did you remove the LENSE CAP ?
2. PRobably there is a small switch that tells the camera that LENSE CAP is on or something dunno
About that recording problem
1. LCD Broken?
2. Other technical issues ...
Im not proffesional or anything :P Wish you luck with better people at this D: .
Feb 20, 2009 | JVC COMPACT VHS-C CAMCORDER
Hp photosmart r725 6.2 megapixels.
If you're getting the 18-4489-957-000 error code, then give it a good tap on the corner where the lens cap is. A little tapping and the lens cover should pop closed. When you turn the camera on again it will probably work just fine.
I was just about to junk my camera when I googled the error code and found this very tip in another thread. It worked like a charm.
May 29, 2008 | HP Photosmart R725 Digital Camera
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Apr 04, 2008 | Philips CDR796 2-Disc CD Recorder
Dropped camcorder
When you dropped the camera you ended up jamming the iris closed. There may be additional damage within the lens assembly. In order to repair the stuck iris, the optical lens assembly needs to be partially disassembled. This is not a project for the novice. This should be taken to a JVC authorized service center for a repair estimate. The estimate will cost about $50 or so.
Dan
Apr 03, 2008 | JVC Everio GZ-MG57 HDD Camcorder
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
NO RECORD
This message usually indicates that a non-audio disc is in the record tray. Please use only blank music CD-R or CD-RW media. Refer to page 12 of the owners manual for more information regarding acceptable media type for the DA-3826. Also, the laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a CD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 07, 2005 | TDK DA-3826 2-Disc CD Recorder
JVC Cybercam GR-DX75 Mini DV Digital Camcorder Logo
437 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
