Question about Hitachi Televison & Video
Hitachi 46EX1B Q902 transistor i am trying to find what this tranistor is part name
  • joewr Jun 12, 2008
    the PART IS nte 2394
  • 4,234 Answers
Q902 is Hitachi part number 2390623 (2SK1181) with a retail cost of $31.88. This part is listed as no longer available. It subs to part # 2000261 (upc1871) which is also listed as no longer available. Either of these may be available generically, but not from Hitachi. Try either of the parts listed above using the generic numbers in ().
Dan
Posted on May 30, 2008
  • ABRsvcs Jun 12, 2008
    Yes, the transistor crosses to the NTE2394. I personally don't user NTE cross transistors unless there is no alternative. The original transistors are still available. The 2SK1181 can be found. Use that.
    Dan
How many fet tranistors are in this unit and what is its max amp draw.?
There are 5 transistors in that unit that you are asking about. The amperage draw is about 50 amps
May 23, 2013 | Palomar Redman Cb Stop LD 450-fet LD Low...
I need advice on how to clean years of dirt and grime in the small ridges of the outside screen on my 1991 Hitachi Projection TV (model # 46ex1b). Thanks :)
Compressed Air Duster available at any electronics store (Best buy, Office Depot, etc) and at just about any pharmacy(CVS, Walgreens)
May 20, 2013 | Televison & Video
Foggy Picture
dear friend your picture tube has a crack in it! probably in the back of it at the neck, or at the picture tube socket pins. it maybe leaking vaccum and taking on some air! have a local tv shop check the picture tube on a tester!
Mar 24, 2009 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
RCA F36650
The H.O.T tranistor and flyback transformer are bad. This can be fixed cheap if you find the right shop. Transformer cost about $22. and the H.O.T transistor is about $6.00. The labor is what you have to shop for.
Jan 30, 2009 | RCA F36650 36" TV
Looking for schematic of Hitachi 43FDX01B TV- 18 pin transistor
The parts that are missing are likely to be the convergence ICs. These are STK392-110 and should be available online from any electonics parts supplier. Expect a cost of around $25 each.
Dan
Dec 26, 2008 | Hitachi 43FDX01B TV
ILO IWT3206
the problem is one of the four diodes in the power supply.(i had the same problem) .the only other thing that would cause this is a shorted horizontal
output tranistor
Mar 15, 2008 | iLO 3200 32 in. LCD Television
Kids.
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
Nov 23, 2007 | Toshiba 32A42 32" TV
Hitachi Projection TV Model 46EX1B
 The most common problems I have found in this model is solder joints going out in the vertical and on the driver transformer.
 I would say the picture tubes are probably starting to go out by now and the technology is changing.
 Look at the new sets. LCD and DLP are using LEDs.
 Manufactures are beginning to equip their sets with ATSC tuners that bring in High Def. stations by using a pair of rabbit ears.
 In a little over a year most signals must be High Definition and the government is supposed to send out checks for about 40.00 to help fray the costs of converter boxes to convert the older set.
 So, my thoughts are, the set is about 17 years old. The cost of repari and the repair itself would be like putting a bandaid on it.
 Capacitors by now are beginning to dry out and solder joints are starting to open up, not to mention that the picture tubes are getting weak and changing luminance and fading..
 Most sets I repair at this age have future repairs.
  Check out the new technology.
Oct 21, 2007 | Televison & Video
I NEED TO FIND THE CHANGING BUTTONS FOR MY HITACHI TV 46EX1B
sorry but your tv moust haven the promted comand manualy olsou you need the remontcontroler Pilot4218 posibel ineed the moor detaill
May 04, 2007 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
Televison & Video Logo
162 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
