Magnavox 42MF230A/37 Product Circuit diagram repair and parts list replacement
HDTV GURU
  • 261 Answers
SOURCE: 42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Posted on Mar 16, 2008
  • 231 Answers
SOURCE: display problem for magnavox 42" model 42mf230a/37
first make sure its not an input problem or from an external source.Disconnect all inputs and see if lines are present with no inputs to tv.if lines affect menu and or ON SCREEN DISPAY (top) there is a good chance (SSB) board could be bad .I would start with this board first ,lvds cable (second) and last the logic board (comes only with new LCD)
Posted on Jun 23, 2008
  • 58 Answers
SOURCE: Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Posted on Dec 05, 2008
stonephoenix
  • 563 Answers
SOURCE: magnavox 42mf230a/37 turns on but no picture or
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're under warranty or you purchased an extended warranty or service plan, the repair costs will be covered.
If you're not in warranty you'll have to pay for the repair. The cost would likely be a minimum of $300+ for parts and labor. The circuit boards in these new LCDs are not cheap at all! I've seen repair costs averaging $450 and up for large LCD TVs.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
SOURCE: magnavox 42mf230a/37 television. it has
When this happens the first thing to check is the Power Supply, you need to check, that, and all the voltages coming out, ensure the voltages are correct. You MUST get a Service Manual. I have searched for a free one, but the only ones I could find were pay for? Link below.
https://www.completeservicemanuals.com/.../magnavox/.../cat_89.html -
What you are experiencing is a symptom, the cause lays elsewhere. Something is shutting down the PSU, either a fault IN the PSU, or elsewhere causing it to shut down. It can be quite a number of things that can cause the same symptoms. Please get a service manual and work through the troubleshooting procedures, to even have a shot. I repair these things all the time, I can tell you from experience, it is NOT easy. Good Luck. Should you NOT choose to do-it-yourself, Please ensure you get a firm "Quote" from the qualified repairer before allowing work to commence.
Posted on Mar 18, 2010
Direct TV code for 2006 Magnavox model 42MF230A/37
Contact DirecTV's customer service. They have a pretty simple setup system for adding remotes.
Jan 18, 2015 | Magnavox Televison & Video
My 42mf230a/37 plasma tv has sound but no picture
Check the power supply, Y and Z sustain boards caps, fuses, burnt parts first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 23, 2010 | Philips 42MF230A/37 42 in. Plasma HDTV
Magnavox/samsung 42MF230A/37 plasma t.v. turns on, no picture.
the only way to check it is to change out boards. the "sugar cubes" are ceramic resistors and should get hot. if you have the correct voltages on the p/s then you will need to replace both the y and z boards. better off buying a new tv. consider letting a professional tech. check it for you, this is not something to be tried unless you know what you are doing. if you really want to do it yourself get the service manual and a voltmeter.
Mar 24, 2010 | Televison & Video
I have a magnavox 42mf230a/37 with black screen
more that likely your set got a serge and bleew a couple of capacitors in the power supply esay to find they will have dome on the tops from venting
Sep 17, 2009 | Televison & Video
Magnavox 42mf230a/37 turns on but no picture or sound?
Jun 18, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox 42mf230a smoked
It should be repairable, however I would suspect the cost to be about half what a new one would be. A circuit board plus labor can easily approach $500. If you're lucky and it was just a few easily replaced components like capacitors venting, then you could possibly get off with a few hundred less.
May 16, 2008 | Televison & Video
Magnavox plasma tv model 42mf230A/37
I guess they are just built to fail. Mine was less than a year old, but they are sending me the exact same unit. Uggghhh
Mar 29, 2008 | Televison & Video
Mar 16, 2008 | Televison & Video
Televison & Video Logo
366 people viewed this question
Top Televison & Video Experts
Electro Med Services...
