Question about Panasonic Televison & Video
I need a replacement bulb where can i get one close by my area code is 27574
  • Panasonic Master
  • 5,138 Answers
For DLP Lamps - Mats Electronics 1-800-628-1118
For R/G/B TUBES Encompass Parts 1-800-638-3328
You can also Look on Ebay under Electronic/Parts
Posted on Oct 09, 2010
We replaced the bulb and it doesn't work
If a new bulb does not work, then it is most likely something else, perhaps the wiring or a connection. You can probably have your machine serviced to get it fixed, or go purchase a light that you can place close to your machine to light the sewing area. There are lights available with attachment clips and a bendable neck that well let you get the light in the right spot. There are also strings of LED lights available on eBay that you can attach to the upper part of the throat to light the work area. I replaced my regular sewing machine bulb with an LED bulb and was surprised how much better it lights.
Oct 30, 2015 | Sewing Machines
How do I fix turn signal lights
turn on 4way flashers to ck bulbs & visually inspect,if no problems found then need 2 locate turn sig flasher unit 4 replacement.Hint m/b look near middle interior;''firewall area'' close to dr.side by floor area .
Oct 09, 2014 | Honda 2000 Acura E L Alternator 1.6l...
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
How to change front turn signal bulb on 2004 corvette
The front of the vehicle has to be raised up enough to remove the close out panel.This is located by on the side under the front bumper.Should be close to the turn signal lens area.After removing this panel you will need to remove the brake caliper cooling duct from the front fascia and position it aside.Then remove the bulb you need to replace.Then just reverse procedure.Hope this helps.Good luck.Let me know if you have any more questions.
Mar 01, 2011 | Chevrolet Corvette Cars & Trucks
HELLO, MT TOSHIBA 52WM48P WON'T TURN ON THE RED LED IS ON WITH THE GREEN LIGHT FLASHING X3 REPEATING THE BULB HAS ALSO BLOWN? IS IT JUST THE BULB OR IS THE TV TELLING ME THERE IS ANOTHER FAULT, PLEASE...
The first thing is to replace the bulb, and that should be your only problem, because when the bulb is is bad it will not start up. so replace the bulb and clean and blow out the area where the bulb goes, and clean the filter, and make sure when reinstalling that it it is is in the correct position and the door to the is close are the way , or it will not start up. You can buy just the bulb, or the hold cartage that holds the lamp. replace the lamp and you will be go to go.
Dec 02, 2010 | Toshiba Televison & Video
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
Jun 15, 2010 | LG LFC25760TT Titanium Bottom Freezer...
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Daytime running lights do not come on
Hiya...
When this happens, it means one or two of the halogen headlight bulb(s) has been burnt-out.
Do this quick and easy self-test:
Turn on the headlight switch to LOW and see if you see one (or none) turns on...you'll know one or two lightbulb(s) need to be replaced....this is why the green headlight logo flashed to tell you that a bulb has just burnt-out.
You'll need to remove the 4 black plastic clips that holds the top grille bracket frame onto the top metal frame that's facing the top radiator area.
If you know which headlight's bulb need replacing, just remove the 3 bolts...two are on top and one is by the side (close to radiator area)
Then you pull the grille toward you gently to allow your hand to access behind the grille and headlight area to reach the white socket that's connected to the headlight bulb.
This requires some patient as it's a tight area for your fingers to wiggle the socket off.
When the new lightbulb is installed, the green headlight logo will appear in the instrument panel when you start the engine.
That'll help!
Jan 24, 2009 | 2005 Chevrolet Equinox
Running lights
Remove 3 - 4 screws on fender cover close to side marker light. Pull fender cover out a bit for you to use your other hand to reach side marker light. By twisting on one direction and here you go the light out. Replace new bulb and replace everything on reverse order.
Dec 30, 2008 | 2001 Lexus RX 300
Televison & Video Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
