Question about Culligan Under Sink Water Filter
I change water filters and water stop coming tank is empty too what i do
    Problem Solver:
  • 8 Answers
Turn the supply valve on
Posted on Oct 09, 2010
I changed out my water filter and now i have no flow coming out of the dispenser.
Is it possible that the filter is on backwards? There may be something in the filter that needs to be removed for proper water flow. Or the filter needs to fill to get the air out for water flow.
Sep 27, 2014 | Samsung RSG307AARS Stainless Steel Side by...
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have a John Deere LT150 and I was almost finished mowing when it stopped. I let it set and started it up and mowed a couple of passes and it stopped again. This was after I just filled up with gas. I...
check your gas cap ro make sure the air hole is not pluged, try running it without the cap for a few min ans see if that helps, you may also anve got some water in the gas and its at the bottom of the tank and sloshs around and ocassionaly runs to the carb
it mkite not hurt to drain the tank into a clean bucket let it sit for a short bit the four all but cup or so back in as water is heavery than gas
also when you have the tant empty maybe blow it out from the fuel line back to the tank look in to see if anything has come back into the tank
Jul 26, 2011 | John Deere Garden
My culligan under sink RO walter system seems to have air in the fitlers when I changed the filters last time. When I turn on the filtered water it spits out for 5 seconds, with a little water a bunch of...
Run the tank empty of water at least 2x. This should take care of problem. You really should dump 2 tanks of water each time because carbon fines can get in the tank when changing new filters.
RJ
Jul 20, 2011 | Culligan Under Sink Water Filter
Changed r/o 3 filters and now water produces 2cups
The pressure on an EMPTY tank should be 8-10 psi. Be sure the tank is empty before checking the pressure. A good way to empty the tank is to connect a small air compressor to the air valve on the tank, open the systems faucet, and turn on the compressor. A bicycle pump works too....Just more of a workout:)
Jul 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
Culligan ac 30 reverse osmosis system - changed the filters, good flow for 3 days then began diminishing. Now nothing comes out of the faucet. Holding tank is empty.
I would pull out all the filters changed and check them. If a GAC filter is used as the post filter, before the RO tank, carbon fines can come out of the filter and can plug up the head on the RO system. Make sure the sediment pre-filter is not plugged and there is plenty of water supply. You may have lost pressure in the RO tank. A 3 gallon tank should have 7psi pressure when totally empty.
RJ
Jun 20, 2010 | Culligan Under Sink Water Filter
No flow from EcoWater undersink filtration unit. Flow stopped so we changed two carbon filters and one sediment filter. Still almost no flow.
The water storage has probably lost its charge. A 3 gallon tank should have 7 psi pre-charge pressure. Tank has to be totally empty to set pre-charge. Turn water off to RO, pump air into tank to force all the water out at faucet, turn tank valve off and relieve pressure until 7psi charge.
RJ
Nov 28, 2009 | Culligan Under Sink Water Filter
No water coming out of my filter faucet.
Okay.
Here is what I would suspect at this point:
- Incorrect air pressure in tank, or
- Clogged filters
To check air pressure:
Empty tank and check pressure -- it should be 7 PSI.
Note: There is a rubber bladder in the tank in which the water is stored -- if this bladder is ruptured, the air pressure in the tank will not hold.
So, adjust air pressure, try system again. If it works for a while and then stops, empty tank and check air pressure for 7 PSI.
Clogged filters?
If the system doesn't work when tank pressure is adjusted, empty tank and check pressure again. If pressure is still 7 PSI, then replace filters.
If tank pressure is not 7 PSI at this juncture, it's probably a ruptured bladder and the tank will have to be replaced. But before you take that tack we should "talk" again.
Please let me know the results...
thanks
Charlie
P.S. I'm assuming you have adequate water pressure on your household system. You're not noticing a drop in pressure anywhere else in the house -- is that correct?
May 27, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO System Tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Mar 19, 2009 | Culligan Under Sink Water Filter
No water coming out of water filter
check to see if the filter is in backwards! most inline filters flow only one way!
Dec 18, 2007 | Kitchen Appliances - Others
Culligan Under Sink Water Filter Logo
44 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Dan Connors
Dan Connors
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
