Computer opens when switched on but turns black before opening the system
    Sergeant:
  • 157 Answers
You need use the combination of keys:
  • Hold Down Ctrrl+Alt+Del Key to get the Task Manager.
  • And then Click on File and new task.
  • And in new Task type explorer.exe.
Hope this will solve the problem.If not leave a feedback and will get back for more solution.
Thanks in Advance.
Posted on Oct 09, 2010
  • 32,281 Answers
It is a backlight problem, caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link to for a solution :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
I can't figure out how to open the back hatch. I can get the window open but not the whole thing. I just got my sub and am freaking out. The guy opened it when he showed it to me before I bought it but I...
ok, the knob turns one way for the glass, and turn the other for the hatch. check suspension light is on means the switch for the air compresser is off. if your truck has the load leveling system, switch is located on passender side footwell mounted about 4inches from the firewall. black toggle switch. if the switch is on, you better see about having the system checked, air leaking somewhere. i swapped mine out after 2 compresser replacements.
Oct 11, 2013 | 2001 Ford Expedition
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
How to open gprs in my iphone black
You can send all your data over GPRS by simply switching off 3G (HSPA) in Settings > General > Network.
If you're talking about GPS (Global Positioning System), you can activate it by enabling Location Services in Settings > Location Services and then opening the Maps application and tapping the small arrow in the lower left corner to zoom in on your location.
The iPhone does not come with turn by turn navigation software, you have to purchase that separately.
Feb 17, 2011 | Apple iPhone 3GS Black (16 GB)
As soon as i switch system on it turns itself off
there could be a problem with one of the connectors try unplugging everything and then connecting it back together if this dont help if you are not worried about opening your system (can still get repaired by professionals even when been opened) and check that non of the things on the circuit board have swelled up. or there is a black thing behind the fan which it the main sound for the amp check the compound has not dried up
Nov 28, 2010 | Technics SCEH790 CD Shelf System
My computer beeps 3 times when i turn it on, and the screen stays black, it wont read boot discs i cant even see what is goin on.
If laptop is out of warrantty...try if you can open the laptop..only 2 screws are required to open from backside.
If you can open it,remove one memory and try to switch laptop on..find out the faulty memory..or it may just require refixing..
Nov 08, 2010 | Computers & Internet
Compaq presario switch button has failed
open the switch three wires red,green,black.or something get another switch with familiar wires make sure the colours go in the correct place
Jul 27, 2010 | Compaq Computers & Internet
What is the fuse # for the power window
On the right side of your glove box, open the passenger door to access compartment #26 30 amp.
As for the power windows, try this.
1.        Measure voltage at 30 amp circuit breaker #26 at fuse block. Meter should read battery voltage. If not, replace or repair open to 60 amp fuse #13 in Power Distribution Center (PDC) as required.
2.        Turn ignition switch to off and measure resistance from ground lug on left side kick panel to ground. Meter read zero ohms. If not, repair open to ground.
3.        Remove master power window switch on left front door. Measure resistance at black wire (terminal one of green connector). Meter should read zero ohms. If not, repair open to ground.
4.        Turn ignition switch to on and measure voltage at terminal 5 of black connector. Meter should read battery voltage. If not, repair open to circuit breaker #26 in fuse block.
5.        Close master window switch. Measure voltage at terminal 1 of black connector. Meter should read battery voltage. If not, replace switch.
6.        Operate window switch. All windows should operate.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 1994 Jeep Grand Cherokee
Inside lights does not turn on when openning door,also my radio does not turn on. the lights will only turn on when switch is open.
HI.
WHERE IS THE ENGINE COMPUTER (PCM) LOCATED IN A 1998 DODGE CARAVAN ?.. NEED TO REPLACE IT. THANKS
Nov 10, 2009 | 1998 Dodge Grand Caravan
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
