Question about Ovens
I was defrosting meat in the microwave and my microwave just quit. The fuse box was checked. MY microwave is blank. What is the problem?
  • 17,130 Answers
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Oct 09, 2010
Wall microwave worth fixing?
There's micro switches and fuses worth fixing on microwaves... if its doing nothing its most likely the fuse on control board. maybe even the breaker.
Sep 01, 2012 | Ovens
Kenmore c970-655822 oven quit during use.....fuse blew where are they
Where is your fuse box located in your home? Check it.
Dec 16, 2011 | Ovens
I have a maytag microwave that just quit. there is power to the outlet but nothing on the microwave works. do you have any suggestions
Hello, there is a fuse on the front display panel. First unplug the Microwave. Remover the screws and and the front panel. On the printed ciruct board will be a fuse rate at 2 amps. If the fuse isn't blown out. The check the HV diode. It about 1 1/2 long, it will screwed down to metal flashing, it has two pronges with two wires plung into it. Take it to a TV repairman/women have them check it. They have electronic equipment to check it. GB...stewbison
Aug 31, 2011 | Maytag Ovens
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
Stove don't work at all
CHECK THE POWER IN THE WALL MAY BE BURNT
Apr 27, 2009 | Ovens
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Nothing is working
There are fuses on/in the stove... you need to locate the access panel and check them.
Robert
Sep 21, 2008 | Whirlpool GBD277PD Electric Double Oven
KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Jun 14, 2008 | KitchenAid KEMC308 Electric Double Oven
Kitchenaid builtin microwave oven # Kemc307KSS
I'm posting this as a solution after I went through several different web sites to and trial & error to fix my "DOOR" error code problem.
The original question I submitted can be summarized: I need to replace the 15A interlock fuse. Can you point me to a manual that describes where this fuse is and how to replace it?
Here's the answer for the KitchenAid KEMC308K series.
1) The service manual is behind the control panel on the left hand side. For my built-in, I turned off the power and removed the oven from the cabinet, exposing the sheet metal shroud. Remove the top piece and there on the left hand side is the service manual.
2) The manual indicates the fuse is in the right rear of the microwave. This is correct, but it is actually accessible through the right side.
As long as I slogged though this, I thought some other people would like to know how to solve the "door" error problem. It could be caused by a faulty control panel, but before going there, the check the switches and fuse in the door interlock circuit. Check this link for a discussion: http://www.gallawa.com/microtech/switch.html
Repair steps:
Remove the rear sheet metal shroud and you see nothing but the back and side of the microwave. Remove the right sheet metal shroud and expose the right side of the microwave. This panel has a bunch of warnings, heed them. However, the are missing one: SHARP EDGES. Think about putting tape on the exposed sheet metal edges. Remove the panel and expose the "guts" of the microwave: Rectifier, wave guide, magnetron, capacitor, and such. The interlock fuse is next to the capacitor contacts. Safely discharge the capacitor (method described in numerous places via google search and the link http://www.gallawa.com/microtech/safety.html ).
After the capacitor is discharged, remove the fuse, verify it is blown using an ohm meter (ceramic fuse - you can't see inside). The fuse is actually (despite what the tech manual says) a 20A 250V fuse. Available at radio shack in a pack of 4 for $2.99. Install the new fuse.
As long as you have this much done, may as well ensure that the microswitches still work. Remove the contacts from the microswitch. There are 2 close to each other. From the 3rd contact to these, one should open when the other should be closed. Ensure that this is true and that when the switch is depressed, the state reverses (the contact that was open is now close & connects to the common). Do this for both door-closed sensing microswitches and replace the wiring to the microswitches. Replace all the microwave side panels and the sheet metal shroud. Turn on the breaker and hopefully, as it was on mine, the "DOOR" error message is gone and it starts up normally.
Oh, when the power comes on the unit runs a self test, lots of blinking lights followed by a power-failure error code when the power comes on. I think it was pf .d=30. Hit cancel and it goes away.
So, this is a pain to do b/c there are about 40 sheet metal screws to deal with and one has to be careful discharging the cap. Pulling the oven out of the cabinet was the hardest part. I build a table at the same height and just slid the entire unit right onto my "work table." If I had to do it again, I'd have the entire thing done in under 30 minutes.
Hope this helps someone else!
sb
Jan 25, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
76 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
