Question about Canon Office Equipment & Supplies
There's nothing stuck in my canon mp220 printer but it still has a paper jam error when there's nothing in it? help
  • Canon Master
  • 17,130 Answers
The paper jam errror is due to the sensor falsely detecting a block. So if there is no sign of any paper jam, you have to remove the motor assembly in the carriage drive.
Now the rollers can be manually turned so as to check if there is any bits struck within. You will have to see if the sensor is clogged with dirt or paper bits.These sensors are optocouplers and reflect the IR.
So it can be faulty or detached. check or replace.
Posted on Oct 09, 2010
Canon pixma mx340 4-in-1 wireless printer thinks it's jammed when it's not. say "error 6000". Assistance is greatly appreciated. thank you
error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
Oct 31, 2010 | Canon PIXMA MX340 Wireless Office...
Canon mp830 displays error message. Paper output
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I keep getting a paper caught warning i cant see any i have a canon mp220
Hello there
Ok you not allways see a paper jam.
Mar 19, 2010 | Office Equipment & Supplies
Paper Jam
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 30, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon mf3110 does not pick up paper
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
My printer keeps saying it has a paper jam. It is a Canon Pixma Mp220
If ALL is cleared and no paper jam is seen then your printer's motherboard has packed up. a common CANON problem.
Jul 06, 2009 | Office Equipment & Supplies
Canon MP220 printer. when i load the paper it starts to go to one side, a rustling sound then paper just gets stuck
I had same problem. Lift up Scanner section and check along white paper feed rollers with torch. I could see something between rollers and bottom roller bar. Lifted up that section of white roller with two small flat bladed screwdrivers. This revealed a " Sweet Rapper" jammed under rollers.Removed printer now ok.
Apr 06, 2009 | Canon Office Equipment & Supplies
Canon mx700 won't print displays error306
Open the top of the printer as if you were going to change the ink cartridge and push the cartridge to the left. Reach your hand inside and see if the paper from the jam is truly out of there. Sometimes when you pull the paper out the front or back from a paper jam there can still be something stuck inside that is gumming up the works.
Jan 06, 2009 | Canon MX700 Office All-In-One InkJet...
My canon mp220 printer is not feeding paper through and there is no paper jams
try turning your printers upside down as it may have something stuck inside it!!! i had a crayon inside mine which caused the same problems as you.
Sep 16, 2008 | Office Equipment & Supplies
688 people viewed this question
old marine
old marine
