Air conditioner problem
Yes i have a fedders A6D24E7A WINDOW UNIT.
it blows very cold for 5 mins and then the compressor shuts off and the fan continues to run if i turn the unit off then right back on it will start up with compressor an blow for 5 more mins what can ni do to fix i alr4eady installed freon fitting but freon is ok help me please
  • 525 Answers
You may have an extremely intolerant cold control, a weak gaurdette on the compressor, a compressor motor winding issue, or maybe an oversized unit for the area you are trying to cool.
Posted on Jun 02, 2008
My fan is screeching but the compressor is blowing out cold air
sounds like you have bearings on there way out in the fan motor
May 21, 2012 | Fedders D Chassis A6D24E7A Air Conditioner
My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The outdoor coil is plugged with ****....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Fedders D Chassis A6D24E7A Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Fedders Window unit
The capacitor's for running, too. The resistor across the capacitor is supposed to be warm but not hotter than boiling. Just disconnect the capacitor and check for a short if you suspect it; but it would be warm someplace.
The timer unit is usually reliable, but if it permits a thermal cutout after 5 min. and the cutout device is a little skittish, it could be either that cutout or a hot-side cutout (or thermostat) failure. Replace, don't bypass.
Jul 13, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Unit Does not blow cold air
compressor is not coming on or low on freon. Not something you can fix yourself.
Jun 10, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Heating & Cooling Logo
288 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
