Question about Kitchen Ranges
How do i remove the oven door for cleaning prima integrated single electric oven
4 Suggested Answers
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
SOURCE: oven door won't unlock
I fixed the automatic oven door lock on my oven. While the door was open, I pushed the button on the upper left hand side a couple of times (the one that senses when the door is closed.) Then I was going to call the repairman when the door closed! I had to run the self clean cycle again to get the lock light to go off, but it worked!
Posted on Apr 11, 2008
SOURCE: can't open oven door after using self cleaning mode.
It just needs to cool a few minutes( 15 minutes or less once everything is yurned off) and will open easily, don't force it.
Posted on Jan 13, 2010
How do you remove the glass for cleaning?
remove door then around the outer edge there are several screws to remove . door will separate into 2 halves . clean glass and dry very well reassemble door and reattach to oven
Apr 26, 2016 | Candy FP855 Electric Single Oven
Self cleaning
Set back on self clean, then after about a minute, switch off. The lock should disengage.
Apr 25, 2013 | Bosch HBN 442 / HBN446 Electric Single...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Cleaning oven window
remove the screws on the perimeter on the inside side of the door and the door will open up to clean in between the two halves,but make sure to get the seals back into place the right way
Apr 14, 2010 | KitchenAid KEBC107 Electric Single Oven
My self-cleaning oven door will not latch. Displays error code dr
HI, This code will appear when there are serious issue that concern the integrity of the door latch mechanism. The control is unable to carry out the lock command, due to this mechanism failing, in this case. This damaged door latch assembly should be replaced asap. Once placed, the unit will preform correctly.
NOTE_ There is a possibility, that the door latch wires are loose. I would gain access to the door latch assembly, if possible, to inspect the wring that is linking the control to the actual door latch. Make sure the wiring harness is connected properly, and that the contacts are not damaged. If all is well, replace the door latch assembly
Nov 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door locked
you would have to remove oven.remove top panel and disengage latch assembly if you are a tech.
Jun 23, 2007 | Kenmore 30169 Electric Single Oven
Kitchen Ranges Logo
1,019 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
