Question about Vacuums
Wiring diagram for White ghd straighteners - Vacuums
How to replace three wire on a Oreck U4180 motor
http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/2e7c587.jpg
ck out these wiring diagrams. usually black goes on 1 side where the black dot is and white is piggy backed on the opposite side.
Good Luck
Aug 30, 2015 | Oreck Vacuums
Need a wiring diagram for an Oreck XL 9100 with a amatek motor.Seen one but to small to read.
Jerry, typically the way it should be wired, is the black wire from the handle cord will go to the closest terminal on the motor from where the cord comes into the back of the power head. There should be a black dot beside the terminal. The two white wires should go to a terminal diagonal from the black wire connection and should also have a black dot beside that terminal. The other black wire should go to the terminal beside the terminal that the white wires are connected to. If there are not two terminals side by side then the black wire will go to another terminal that will be on the same side of the motor as the white wire. Hope this helps!
Jan 28, 2015 | Oreck Vacuums
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck U4148 motor wiring
Pat, I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Mar 09, 2014 | Oreck XL2600 Vacuum
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
Hello, I am looking for a wiring diagram to install a touch/dimmer switch by "Comfort" mdl # RH-934B - Darjung Ind Ltd. It has a standard lampcord (two wires) coming from it as well as one...
the black and the white will go to the lamp ,eg,output.The yellow is the sensor wire which should be firmly attached to the metal base of the lamp
Mar 25, 2011 | Vacuums
Model 7901-1 bissell proheat motor runs but won't squirt or ****, just quit 1/2 way thru carpet.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghd
Apr 11, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Need a wiring diargam to look at
You won't find a diagram.
You will have series of yellow and white and sometimes gray wires on the outside of the motor housing and often a letter code etched on the housing , indicating the original wiring from years ago, red, blue, yellow, however the newer wiring eliminated those colors.
These wires are almost fool proof as they will align with the longest wire at the furthest point,a center one piggy backed , etc however before starting please post back to advise if you have removed the rewind and or motor and if so, did you disturb the motor wiring inside the motor shroud.
Please post the original problem you opened the vac for as well and I will try to walk you through this
Nov 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrical
I have the same vacuum at home and can take a picture, but I believe it is wired in this order. Hot wire (black) from cord goes to the switch then the switch to the fuse, then the fuse to the cable that goes down to the light and motor. The neutral (white) wire from the cord is connected to the neutral (black with white stripe) side of the wire going to the motor and light.
Jan 26, 2009 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Vacuums Logo
204 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
