Question about Ovens
Hi there. I need to change the fuses on my oven,
Hi there. I need to change the fuses on my oven, but I can't find them. Where are they? Thanks
    Genius:
  • 1,417 Answers
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks and thanks for visiting.
    Posted on Oct 10, 2010
    Oven not producing any heat
    just the oven? then more than likely the element. if the stove eyes are not working as well, then your looking more at a sensor, thermostat, fuse, breaker, etc. almost always an element though
    Mar 20, 2012 | Electrolux Ovens
    Hi, F3 mag curr. what is means and how do I fix it?
    F3 is an complex code.
    Easy fix is look at the transformers and the capacitors and the diodes.If it seems that any component has changed its appearence then fix it and replace the F3 fuse(3rd one from the front).
    If the magnetron is bad ,then to check that you must know how to use clamp ammeter.
    let me know if you know how to use clamp meter .
    I will give you the solution .
    NOTE oven has 5000V in it.
    make sure you dischared the capacitors.
    Thanks
    please rate my work
    Apr 16, 2011 | TurboChef TORNADO Electric Oven
    Hi. Just need to know if the oven door is adjustable on our AEG double oven cooker? The bottom oven seems to 'leak' hot air slightly from the top right hand corner and when you press on the same point the...
    Hi there is no adjustment. to fix it you will need to change both hinges on the door. Some models have a roller which may need changing (on the oven frame where the hinges are located)if the door is creaking when opened or closed. wherever you go for parts you wil need the model and product no from the oven located around the door area.
    Jan 20, 2011 | Ovens
    Converting fromTown Gas to LPG in gas cylinders
    Hi
    Thanks for using FixYa. If your range/oven doesn't seem to work at all, check these:
    Fuse/circuit breaker
    Check to see if power is getting to the range/oven. If even a light won’t turn on then check for a blown fuse or tripped circuit breaker.
    Main wiring
    Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
    Range/oven wiring
    There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 15, 2010 | Ovens
    Display reads code F03 on Whirlpool oven. Can I
    Hi
    Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
    Thanks
    Rylee
    Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
    Oven tripped fuse and will not turn on
    Hi!
    If the oven is not working, you need to check the fuse on the main PCB - If the fuse is good check for continuity between the fuse and L3 (drive motor terminal) - If this circuit is open the PCB is bad and must be replaced. When re-assembling please be sure all the wiring is correct.
    For your reference, you can check the following link---
    Dacor Epicure Electric Oven Technical Manual
    Please do accept this solution and revert for further assistance.
    Thanks
    Rylee
    May 31, 2009 | Dacor ECD230 Epicure Electric Double Oven
    Recently wired a double oven with isolator switch
    Hi, there's definitely a electrical problem.
    First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
    Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
    The reason is sometimes grill elements are corroded and only trip after a few minutes.
    Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
    Cheers
    Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
    Oven not working - fuse blown
    Probably the oven element has gone .Disconnect element and try again if fuse does not blow, change element.
    Plz rate this solution.
    Thanks
    Dec 14, 2008 | Smeg Ovens
    F3 MAG Error
    open the right side panel and change 3rd fuse from the left
    Oct 18, 2008 | TurboChef TORNADO Electric Oven
    Oven doesn't work.
    HI. thanks for your question. i would replace the 2. 30 amp fuses in the stove. try that. if not repaired. check the timer. it must be set to MANUAL, for the oven to work, check that.thanks the appliance doc. please rate my answer. thanks
    Oct 08, 2008 | Ovens
    Ovens Logo
    696 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
