Question about Pantech Matrix Cell Phone
No sound at all works on my phone. The volume is all the way up and the profile is set on vibration and melody. Everytime I get a call I can't hear anything and the other person can't hear me but the ringtone plays when I get a call. How do I fix this problem? -nick
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
My phone has a very low sound that i cannot even hear it when it is in my pocket.It does not even vibrate in such a way that i can detect it.
you can increase the sound level,
the sound level for tones, speaker fone, etc,
can be increase even then if it is at max (level 4)
you still can do it,
just follows the instructions!
**************** HERE WE GO **************
Enter the following code:
*#8999*8378#
(You'll be shown menu, then ...)
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
There will you see a number.
there are five (5) Melody Levels" of it.
(and currently, you are at level 1 and after
pressing the "save" button, you will move to
level 2 and so on .........................)
you have to change the values of all the levels.
and as the resultant, it will give increase the
melody sound!, your tones will more louder,
even more louder then the max. ringing volume.
the level wise numbers are: (as its my setting :-) )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... :-)
meanwhile, try my figured-out combination!
IF U R SATISFIED PLS VOTE ME
Jan 21, 2010 | Samsung SGH-E370 Cellular Phone
I want the keytone to be silent - how do I set it to silent?
You have to do the following:
Sound Profile
You can customize various sound profiles for your phone by
changing the sound settings.
1. In Idle mode, press the Menu soft key and select Settings
➔ Sound Profile.
2. Highlight one of the following sound profiles:
• Normal
• Silent
• Driving
• Outdoor
3. Press the Edit soft key to access the sound settings.
4. Press the Change soft key to change the "phone" option.
• To move between the various tabs, use the Left and Right Navigation
keys.
• To highlight individual options, use the Up and Down Navigation keys.
• To change the setting for a highlighted option, press Change ( ).
There you have these options:
– Keypad Tone: allows you to choose between Beep, Xylophone, and
Mute (no tone) for keystrokes on the phone.
– Power On Type: allows you to select the way in which the selected alert
is played when the phone is powered on.
• Melody: the phone sounds the selected melody.
• Vibration: the phone vibrates.
• Vibration & Melody: the phone vibrates and also plays the
melody.
• Mute: the phone neither vibrates nor plays a ringtone. The only
indication of a message is an alert on the display.
5. Press the Save soft key when you are finished.
Normal Profile
To access the available options for this sound profile, press the
Edit soft key.
keys.
• To save your changes, press the Save soft key.
This should do it.
If you still have some problems please download following manual and go to page 69 where you find all related info.
Propel Manual
.pdf
Hope it helped.
Nov 20, 2009 | Samsung Propel A767 Cell Phone
The volume is not working on our Samsung HPT4254 Plasma. We have a RCA surround sound connected to it as well as our cable box.
First check to make sure that the audio isn't "Muted". Second, Go into the user menu and check to make sure that the "Melody or Chime " is turned "on". Third, Turn the volume up half way.Fourth, Turn "off" the set. You should hear a "Down" Melody or chime. Next turn "on" the set. If you did hear the Melody when you turn the set "on" or "off" then the audio system in the set is ok. If you did not hear the Melody then the Main bd needs to be replaced. Have a trained Samsung tech repair your set.
Jul 12, 2009 | Samsung HP-T4254 42 in. Plasma Television
Samsung U900
I came across your post when investigating exactly the same problem. In my case I did not realise that vibration was not enabled until the profile Call Alert Type was set to 'Vibration and melody' (mine was set to Melody and I didn't notice the other options). HTH.
Sep 29, 2008 | Samsung U900 Soul Cellular Phone
Can't get the phone out of vibrate mode
lol just hold the * key down bottom left
Oct 07, 2007 | Cell Phones
Pantech Matrix  Cell Phone Logo
22 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
