Question about LG Televison & Video
Normal headphone jack does not work - LG Televison & Video
  • 8,596 Answers
I don't have your exact model number, but double-check your manual, and make sure you don't have to change your audio settings to reflect headphone output only. If there is no such option, then unplug your TV for 30 seconds, replug, and try again. If that fails, the jack is faulty and needs to be replaced - contact manufacturer if it is worth it.
Posted on May 30, 2008
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
How to connect normal headphone in nokia x3
Just plug in the normal headphone into the headset jack, it should work without any problem, but if there's problem, try with different headset or headsets with different jack..
Hope this helps.
Thanks for using FixYa.
Sep 09, 2011 | Cell Phones
I have sound from my headphones but nothing from the speakers, pls help
So it IS acting like headphones are inserted even without them. Stop messing with other connections. The jack for the headphones has spring-loaded normally opened and normally closed contacts that are designed to disconnect the speakers when the plug is inserted. Perhaps the NC connection isn't making good contact on headphone removal. With the Volume turned to soemthing NOT LOUD, repeatedly insert/remove the jack to see if it makes any difference; or with power OFF squirt a little tuner cleaner in there first and repeat with the headphone jack.
Jul 25, 2011 | Bose Audio Players & Recorders
My head phone works very good but the microphone doesn't work
When you say headphones do you mean the music headphones, like speakers, because they go in the headphone jack in the computer while microphones go in the microphone jack. The microphone is normally a pink color and the headphone jack is normally green. If you already knew this try wiggling the microphone to see if there is a brake in the wire, if that dose not make it fissile in and out then its something wrong with the microphone its self and should be replaced
May 03, 2011 | Logitech (980240-0403) Microphone
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
( no sound from speaker) i detached the grundig headphnes from my satellit 800 millenium -- the speaker remained 'silent' --otherwise, the radio appears to be functioning normally -- the radio functions...
it maybe that the cut off switch in the headphone jack has stuck as you place in a jack to the headphone socket there is a small switch that mutes the normal speakers and this should switch back on as you remove the headphones, this may have stuck. you will have to open the back and check the back from inside. try to short the mute and see if that is the problem. maybe squirt a small amount of contact cleanrer spray in the jack hole and insert and remove the headphone jack a few times this may resolve.
I hope this was helpful
Dec 12, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
Headphones arent working with keyboard
yes its in the keyboard jack.
Aug 14, 2009 | Music
Ipod plays with no volume
If the sound isn't working from the headphones then normally it's just a new headphone/hold switch cable that's needed, but if it's not working from the docking bay either then you have a problem with your logic board.
Oct 26, 2008 | Apple iPod MA446LL/A MP3 Player
Small headphone jack on crap headphones from Brookstone.
i used a cellphone adopter when my headphones broke.
Nov 28, 2007 | Brookstone TinyTunes MP3 Player
Televison & Video Logo
127 people viewed this question
Computer Repairing
Computer Repairing
