Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a kenmore elite side by side bottom freeze frig.There is a huming noise coming from the frig.sounds like the compressor. The freezer is starting to frost over. I can make the noise stop by opening the door to the frig. If you close the door it starts again instantly.
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
The humming noise your hearing is the evaporator fan blades striking the ice build up on the evaporator. The fact that you have ice build up is a sure sign your refrigerator is not defrosting.
The door switch controls power to the evaporator fan.
I am going to use this model number 106.57071791 as a parts reference that MAY be different from your actual model but it is close. This model is a mechanical control refrigerator. You may have the electronic control version.
Take a look at item 6 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000/P8100197/00012?blt=06&prst=&shdMod=
It will be located in the top left of center & front of your fresh food compartment. It will be circular and will have 2 tabs on it with an incline so that if you were to rotate the tabs with something flat it would only turn ONE direction.
Either use your finger nail or something flat to SLOWLY rotate that until you hear an audible click. (Everyting stops but the lights) This is initiating an automatic defrost cycle. After about an hour come back and check to see if your refrigerator has re-started. If it has not restarted there is definately a problem with the automtic defrost circuit. That can be the timer (listed above), The defrost element under the evaporator, the Bi-metal thermostat on the evaporator or wiring.
All parts can be found via this link / section
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000?pathTaken=
If none of the links work go to http://www.searspartsdirect.com and enter your model number where it says find it fast and choose model search.
I guessed at the model number so if this does not resemble your refrigerator or you have the electonic control board type refrigerator please respond with your model number.
Thanks for choosing FixYa,
Kelly
Posted on Oct 09, 2010
Kenmore Model 10654613300 Freezer over freezing
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Sep 21, 2014 | Kenmore Elite Side By Side Refrigerator -...
Refrigerator is 6 yrs old. On last Thursday, started making this ticking sound and then shuts off real fast. No enough time to cool food in frig. Replaced the capcitor and thought this would fix...
Good day,
Sounds like a compressor problem, but you said you replaced the capacitor. I would consider the start relay as the issue assuming the compressor itself is still good.
You should be able to take the relay to any decent sized appliance parts house, they are usually more than happy to test it for you.
Kenmore is the name Sears has manufacturers affix to their machines. They are usually Whirlpool, Frigidaire, or GE.
Sep 22, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Mar 09, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Jan 19, 2009 | Kenmore 73503 Stainless Steel Bottom...
GE Stainless Steel Side by Side - Loud Huming and Whoosh noice
you should not hear it from that far away. It sounds like it may be compressor related. The only thing you could check to make sure is remove the lower rear cover and check the condensor fan and listen to the compressor to see if thats where the noise is cmming from. Check the fan in the freezer too.
Aug 06, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
147 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
